Home > Puma (Tdci) > Puma loss of power and temp needle into red
Mongolia
France
I have a Defender Td4 2007 with 165000 km on the clock. All is well, except that sometimes, especially in the long ramps with the throttle pedal down (I'm still in charge over 3,2 tonnes), there is a loss of power: first, the engine looks to limit around 2700 rpm and if I keep the pedal down, it goes in extreme limp mode (about 800 rpm), the temp needle sharply rises into red and there is no MIL amber light.
The temperature stays high for around 10 or 15 seconds, then comes down back again rapidly to normal, the problem disapeared and having a “cool” driving, I can once again have a normal driving.
When a slight loss of power occurs, if I put a lower gear for having a small reserve to accelerate, it does not turn onto limp mode .
This occurred the first time in the Dolomites in Italy (km 55 000 on the clock): the EGR valve was changed, fuel filter and thermostat changed, MAP and MAF sensors cleaned, water pressure system is OK, ... and every time, none fault codes with the scanner.
This occured several times: in Brazil (km 60,000), in Chile in Paso del Libertador (km 90,000 ) , in the Ethiopian mountains (km 140,000 ), ........ Now, I'm in Cape Town, Africa South.
For more information, in Ethiopia, under the same conditions, another TD4 (year 2010 and 60000km on the clock) had the same problems as mine, while the third TD4 (year 2008 and too 60000km) was OK?
If anyone can help me because I'm always looking for a solution.
Thank you so much
Post #246196 24th Jun 2013 10:35am
Naks
Sounds like you are gunning it in 6th and the ECU is cutting power to prevent damage to the engine.
Lots of SaFas had this issue as well, cured by fitting a bigger intercooler. --
Post #246200 24th Jun 2013 10:44am
dgardel
Italy
Check the main relay under the driver seat Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #246204 24th Jun 2013 10:48am
Mongolia
France
[quote="dgardel"]Check the main relay under the driver seat[/quote]
There is no relay under my driver seat
Naks:
what's the meaning of SaFas
.....if I decide to change my intercooler, do you know where near Capetown et what price?
Now, my car is stored by Duncan, African Overlander in Stellenboch
Post #246225 24th Jun 2013 11:56am
Naks
[quote="Mongolia"]
dgardel wrote:
Naks:
SaFas: South Africans Wink
All SaFas get their intercooler from the UK, usually from Allisport or AliveTuning, the local products are just not goof enough.
BTW, I live in Stellenbosch. If you want to see a Puma with BAS remap + Allisport intercooler, give me a shout Thumbs Up --
Post #246229 24th Jun 2013 12:08pm
dgardel
Italy
Naks:
Sorry you are LHD Embarassed Embarassed Embarassed
Passenger seat
Thank you so much
there are (depending if your car have ABS or not) it is the 1st (w/o ABS) or the 2nd (with ABS).
Check the socket contacts (they must be solid) and the relay teperature after 10-15 min of drive.
When the water temp. indicator is going to the RED zone, normanlly it is a problem "main relay" related.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #246247 24th Jun 2013 1:05pm
dgardel
Italy
Should be, but the strange things is the Water temp on RED (comon on main relay related failure) with normal H2O real temp Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #246250 24th Jun 2013 1:09pm
Mongolia
France
SaFas: South Africans ;)
BTW, I live in Stellenbosch. If you want to see a Puma with BAS remap + Allisport intercooler, give me a shout :thumbsup:[/quote]
Thanks Naks
Now i'm stored in Joburg but I wil be in Stellenbosch next september
So, I wil shout you to see your car
Post #246252 24th Jun 2013 1:24pm
Mongolia
France
[quote="dgardel"][quote="Naks"]Sounds like you are gunning it in 6th and the ECU is cutting power to prevent damage to the engine.
Lots of SaFas had this issue as well, cured by fitting a bigger intercooler.[/quote]
Should be, but the strange things is the Water temp on RED (comon on main relay related failure) with normal H2O real temp[/quote]
Yes, it occurs when I'm gunning on 6th but why my water temp on red ? and how to know the real water temp?
I think there is only one sensor CHT on the back of the engine cylinderhead
Post #246499 25th Jun 2013 6:44am
dgardel
Italy
It is an electric problem related!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #246510 25th Jun 2013 8:01am
Naks
Mongolia wrote:
Yes, it occurs when I'm gunning on 6th but why my water temp on red ? and how to know the real water temp? I think there is only one sensor CHT on the back of the engine cylinderhead
Don't gun it in 6th when towing uphill, rather gear down.
The only way to know the coolant temp is to fit a Madman-type engine monitoring system or read it off with a Scangauge/Ultragauge --
Post #246530 25th Jun 2013 9:19am
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Mongolia,
I've experienced both the intercooler and relay issues discussed above.
If I was travelling up long inclines in 6th gear at altitudes over 1,000m above sea level in warm weather (30+ degrees) the vehicle would go into limp mode. It would cut back power and I wasn't able to get the revs over 2,200 rpm in 6th and 2,500 in 5th if I geared down. The temperature gauge would not move and no MIL light came on, nor were there any fault codes stored. The only solution at the time was to throttle back and take it slowly. I fitted a new intercooler 6 months ago and the problem hasn't resurfaced.
The relay issue would happen at any time, even just after start up. The temp needle would shoot off into the red and the vehicle would cut out. This got progressively worse over a couple of weeks, until Land Rover replaced the relay. They diagnosed the fault quickly so maybe it stored a fault in the ECU, but I can't say that for certain.
Replacing the relay is certainly going to be the cheaper option, but it may not be the cause of your problems. The intercooler issue is known to Land Rover South Africa, but they are of the opinion that the standard intercooler is good enough - there are plenty of us who disagree, including workshop managers, who ostensibly work for LRSA through their franchises.
You need to be very clear on the conditions in which your limp mode occurred, if it was random have a look at the relay, but if it was hot and at altitude and the vehicle was under strain, the intercooler may well be your problem.
PS. I imported my intercooler from Allisport in the UK, but there is a local version (the core is made in Europe) for sale, which is significantly cheaper.
Post #246563 25th Jun 2013 12:49pm
bvandyk
robharvey wrote:
Mongolia,
Yeah, the local version is R4600 at the moment.
Post #246598 25th Jun 2013 2:32pm
Mongolia
France
[color=red]Don't gun it in 6th when towing uphill, rather gear down.
The only way to know the coolant temp is to fit a Madman-type engine monitoring system or read it off with a Scangauge/Ultragauge[/color][/quote]
Hi Nak's
Currently, I'm still in France but I come to Stellenbosch on September 19 and I have to get my Defender from Duncan (African Overlander), where it is stored for 3 weeks.
I still have my issue of power loss with needle temperature which rises rapidly in red and go into limp mode. It would not be too disturbing if it is only when this happens, my coolant level go lower and I have to add about 1/2 liter of liquid. So I think may be a head gasket issue?
Would you know about Capetown:
- A good diesel mechanic who could check my injectors (they are 170000km)?
- A good garage that could check this head gasket issue and if necessary change it?
In advance, I thank you for your help and sorry for my bad English.
Regards
Gerard
Post #263629 4th Sep 2013 8:36am
Naks
Mongolia,
Yeah, sounds like a head gasket issue if you are losing coolant.
Close to Stellenbosch I would go to Schalk Burger 4x4 (+27 21 883 4465).
In Cape Town itself, there are few good indies: LR Services, British 4x4, it would help if you let me know where exactly you will be based.
Vous m'appelez quand vous arriver à Stellenbosch, je vous donne mon portable par PM Smile --
Post #263631 4th Sep 2013 8:43am
