![]() | Home > Maintenance & Modifications > RRC hand brake on a puma ? |
Has anyone fitted a RRC handbrake to a puma ?
This was a modification I did to my td5 110, its basically relocating the hand brake to the side of the cubby, makes for easier application of the hand brake. Only the hand brake needs to be changed on a td5, the cable just needs adjusting - thats it. I got the initial idea from here: http://www.reedx.net/landrover/mods/handbrake/index.htm not a great photo but you can see it installed here, it's a little higher and back towards the cubby ![]() Click image to enlarge |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 ![]() ![]() ![]() |
This going to my to do list Steve
now your leg don't lay on the handbrake isn't ? |
sat13 Member Since: 06 Jun 2010 Location: Cheshire Posts: 70 ![]() ![]() ![]() |
I changed the handbrake lever for an RRC one a couple of years ago, on my 09 Puma 90 xs. It’s so much better relocated next to the cubby box. I set it on an aluminium plinth bolted through the floor panel, using the original brake cable set at a different angle to connect up with the new linkage. I can now rest my leg in comfort while driving. I used the original gator over the new unit. It looks quite good in the new position. When it went in for its first MOT the tester thought it was standard fit because it is an XS model, I just agreed. Also the hole left by removing the old lever was blanked off with an aluminium plate using the two tapped holes that held the original lever on.
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Its on my list of things to do as well. If anyone is interested the part number is NTC2794.
Regards, Mark |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
A disco handbrake lever here on eblag
Looks the same as a RRC one... £20 too. |
Did you use a lever the same as the one in the link I posted above?
(If so, I know where I can get one for mine) |
Yep
![]() ![]() Click image to enlarge Ray Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
cool.
looks wierd with two handbrake levers! |
It did a bit! But not anymore
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
I used a Discovery 2 handbrake
Are the D2 levers much different?
No Jim much the same as RRC
[quote="ibexman"]No Jim much the same as on the RRC plus side you can use the original rubber boot turned upside down e]
