- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Dieselhead
Gearbox out put shaft movement | |
Now we are trying to sort out the lack of drive on my mates 09 puma
It was making noise from the transfer box area so we wipped it off this morn & opened it up for a closer look. We could not find anything wrong, all moved & gears had all there teeth.
As we slid it away from the gearbox we noticed the out put shaft move. Quite alot. We thought that the shaft had broken We went through the gears & all seem fine
Now, we have done a gearbox job in a puma last year & for what I can remember the shaft did not move
Now should it move?? It looks like an extra piece which is put on to suit the transfer box. I would hate to refit & find it will cause more probs down the line
We found the problem to the lack of drive though. A very badly smashed front diff which also now needs stripping down
At least it all came apart quite easy when you have help Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
12th May 2013 5:26pm |
