Home > Puma (Tdci) > Remap and noises after engine shutdown. |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Remaps don't generally cause any extra ware than a normal standard car would have providing safety limits are adhered to and turbos are not sent over speeding on WOT. Induction noise will change slightly from the standard sounding noise at most engine speeds used under max rpm.
I have not herd or any brand remap killing a puma turbo since 2007. |
10th May 2013 8:38pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6041 |
Because manufacturers have to take into considerations the worst case servicing history (farmers, hire companies etc, who will have drivers run them into the ground without checkin the oil) and a vehicle that might have to run on the poorest quality of fuel, in the harshest environment (and maybe said vehicle travels a lot, so goes from cold to hot to dusty to wet etc) they want the engines to last at least 100k miles and be at least a bit reliable. The average owner who bothers to get a remap is going to be mechanically sympathetic, polish the engine and use good quality synthetic oil. not some knuckle dragging ape who pours in whatever oil oil they happened to find in the shed then rags the engine from cold. |
10th May 2013 9:15pm |
Without this tuning into a tit for tat about tuning and the ins and outs related, please remember the Mk7 transit 2.4TDCi and its bhp versions though admitinglly still a little less than most offered remaps. and also the link in my signature below on the 2007 developement which shows just some of the depth I personally go to when doing my work. I have tests made, results good and bad, confirmation of what works and what does not etc as well as failures all under my belt. One thing Im not short of is testing and developement information from 2007 until now totalling 6 years work without counting the 6pm until 11pm home work, unlike some companys who offer products and run! I appreciate its each to their own regarding remaps but not all are bad and dangerious Regards Pete |
10th May 2013 9:20pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
I go with the first bit of what you have said Jim as that's kinda accepted that engines and vehicles are built to cater for a wide ranging customer base and fuels for that matter.
Not sure every owner of a remapped engine polishes it and treats it with the kit gloves you suggest though! |
I didn't say every, I said the average....
10th May 2013 9:24pm |
Pete, I am not questioning your development work at all, I am merely saying that individuals thinking of going for a remap should consider any potential and unknown pitfalls. Its impossible ot prove either way whether remapping has a negative effect on an engine and until some boffin runs a standard and remapped lump alongside each other for several thousand miles, strips and rebuilds, measures and records we will never know. |
10th May 2013 9:30pm |
so what does the average mean? |
10th May 2013 9:33pm |
What do you think it means? or do you just want to argue with eveyone on here?
10th May 2013 9:38pm |
Hey sorry for not going with the flow! |
10th May 2013 9:39pm |
eh? where did I mention that?!
"the average" is pretty self explanitory I think. Whatever. |
10th May 2013 9:41pm |
Nothing wrong with challenging the facts, or giving folk something to think about before they dive into a purchase is there?
10th May 2013 9:43pm |
Meanwhile, back on topic Thanks Pete, I understand your explanation Given that the noise is from the turbo as it is spooling down after shutoff from idle [and as stated above not directly after revving] I am still unclear as to why it's loud enough to clearly hear with the remap and not in standard tune. If it made the same amount of noise in standard tune that it does with the map it would be easily discernible over the EGR cycle etc. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
10th May 2013 9:52pm |
Air paths can be the only explnation of a different induction noise! as said the map does NOT adjust the turbo at idle speed at all.
Take the inlet pipe of the turbo and watch the compressor spin down while you listern to it. |
10th May 2013 10:05pm |
I'm probably going to sound like a broken record but...
Given that the turbo is not spinning any faster at idle with the map as opposed to the standard tune I still wonder why it is the turbo itself does not make any spooling down noise after engine shut down in standard tune but does with the map. I refer to mechanical rotation type noise from the turbo itself. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
10th May 2013 10:30pm |
