![]() | Home > Maintenance & Modifications > Rear door hinges |
| bcarlin Member Since: 24 Sep 2011 Location: lanarkshire Posts: 290
My rear door hinges are worn and the door is banging a bit going over bumps. Can I replace the pins easily enough or is it best to buy new hinges ? Had a look at these http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...3cbf2a2afe
| WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748
If you end up buying new then I can recommend these genuine hinges from RJ Land Rovers. I replaced all mine on my 300tdi with these. They are TD5 hinges and come in random colours for you to re spray. Mine came white. Just make sure you have the correct gaskets/shims as they differ between 300tdi/TD5 etc.
http://www.rjlandrovers.co.uk/all-parts-an...ender.html Last edited by WarPig on 30th Apr 2013 10:24am. Edited 2 times in total |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
Pins are pretty easy to change
| Mattyboy Member Since: 05 Dec 2012 Location: Sudbury Posts: 58
I got some hinges from RJ as well, new ones and they came in Bright orange! re paint them and then fill them with spray grease, stainless steel bolts and your away 07 Defender 90 TDCI
98 Defender 90 300 Tdi Land Rover Freelander MG B GT CBR 600 AEC Matador but no washing machine |
You should have left them orange to match the new 65th anniversary edition
| All times are GMT |
