Home > Puma (Tdci) > P068A fault code |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2109 |
I have reading a P068A fault code (ECM Power Relay Load Circuit: De-Energized Performance Too Early)
Nothing affected in the driveability but better check to do not have a major problem in the future. According some WEB page (http://wiki.ross-tech.com/wiki/index.php/P068A/001674) The causes can be: Fuse(s) faulty Ignition Switch faulty Wiring and/or Connector(s) from/to Power Supply Relay (J271/J317) faulty Power Supply Relay (J271/J317) faulty And the solutions: Check Fuse(s) Check Wiring and/or Connector(s) from/to Power Supply Relay (J271/J317) Check/Replace Power Supply Relay (J271/J317) Anyone with experience in this issue? Cheers and thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Apr 2013 7:14pm |
Hi Eduardo,
Just did a quick search. Lorryman will be the man I would 'pm' first. http://www.defender2.net/forum/topic14410.html?highlight=p068 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Apr 2013 7:19pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2073 |
I love this Forum !
there is no end to the skills and experts on here who galdly share their leranings for the good of others. Lorrymans post was Fab! many thanks guys!! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
28th Apr 2013 9:02pm |
I did a search in all the WEB but I forgot to make the search here
Problem solved. Thanks KF9 for the reminder! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Apr 2013 11:40pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2599 |
Yeah, that fault code is also stored in mine often since I use a BAS remap tool --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
29th Apr 2013 12:51pm |
