Home > Puma (Tdci) > Alarm aerial mod |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Anyone?
4th May 2013 9:14pm |
What range have you got with yours as it is? If you go through life with your head in the sand....all people will see is an ar5e!!
4th May 2013 9:26pm |
Varies, from the passenger side it's 20m or so, but the drivers side I am touching the side window!
4th May 2013 9:38pm |
I think that you have some form of modification as 20 metres was totally unachievable from any angle without the modification. 4-5 metres maximum. I extended mine up the driver's side window pillar and get about 20 metres from that side but a reduced distance from behind the passenger's side unless I stick the fob against my bonce. If you go through life with your head in the sand....all people will see is an ar5e!!
4th May 2013 10:39pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19615 |
What would happen if it was some how linked to the radio aerial? Not sure if that is possible or indeed a good idea though.
(probably isn't a good idea) Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
4th May 2013 10:43pm |
