Home > Puma (Tdci) > 2Q's. |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
I'm pretty sure that the jets are An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
9th Apr 2013 10:41am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
Yes. |
9th Apr 2013 10:44am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
You can get stainless ones on eBay John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
9th Apr 2013 11:30am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19615 |
And from Mobilecentre. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
9th Apr 2013 11:51am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Good info guys... Fitted the new jet with a tap from a rubber hammer and fitted chromed ring from GEMM Larbert. 30m max. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
9th Apr 2013 12:49pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
The jets are a really tight fit Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
9th Apr 2013 12:53pm |
Not tight enough to stop them popping off when frozen. Quite handy the jet comes seperately now. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
9th Apr 2013 12:57pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
NO! they are not the same on the inside! The rear one is shorter.
Stainless headlamp rings are available from us as well. WANTED: SII or SIII in max 1.5k |
I only bought the twin jet part not the threaded part with the brass nut, I never knew the parts came split. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
9th Apr 2013 1:02pm |
did not know that as well WANTED:
9th Apr 2013 1:09pm |
Yes, genuine LR part too. I always felt separating the jet from the stub made it looser. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
9th Apr 2013 4:46pm |
I originally knocked mine off with a brush at tnhe jet wash. I stuck it back on with a smidge of marine sealant many months ago, seems to have done the trick as it's still there.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Apr 2013 4:48pm |
