Home > Puma (Tdci) > battery |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 |
Looks like RS South Africa has them ... 4,700 Rand or about £340
http://za.rs-online.com/web/c/batteries/re...4294959776 |
16th Apr 2013 10:57am |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
Optima bluetop 75 ah goes for R3900. A bit cheaper...ill just have to mount it sideways.
17th Apr 2013 9:01am |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
These are all expensive batteries. Don't seem to last that well. My OE battery is now 5 years old & still OK so far, touchwood).
WRT battery size, has anyone fitted batteries in a different place to where they were designed to be e.g. in a boxed part of load space. Less restriction on size & set up, just a bit more wiring needed. I see Odyssey sell brass terminals for their batteries. Are they better than lead? Also would marine batteries with steel posts be less corrodable? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
17th Apr 2013 9:47pm |
So.....if the expensive batteries dont last well one might as well just buy a conventional one......
18th Apr 2013 11:44am |
Yup. A leisure battert with big storage, CCA etc like Numax for 1/3 the price. Worth a try the first time.
I'd go big O if I found a sale or discount priced one somewhere. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
18th Apr 2013 10:31pm |
I replaced an old leisure battery with one from this lot:
http://www.ebay.co.uk/sch/batterymegauk/m....1439.l2654 Next day delivery and I specified a 110Ah deep cycle/cranking battery that was lower in body size to the original starter battery and it fits alongside in the battery box, it's a bit snug but it works for me and for £74 was a little easier on the wallet. |
18th Apr 2013 11:05pm |
Any comments on this battery? What exactly is an AGM?
VARTA Professional Dual Purpose Agm LA 95 or LA 105 |
23rd Apr 2013 8:39am |
AGM: absorbing glass mat. Instead of the plates sitting in a liquid acid bath, they are "wrapped" with a glasmat that contains the gelled liquid. So they can't spill and don't need filling up.
not 100% correct explanation but close. |
23rd Apr 2013 11:18am |
OK....the deed is done.....
Fitted a Varta start-stop plus 105 amphr AGM in the end. Same width and height and only 4cm longer. Had to bend the battery tray a bit to accomodate the extra 4 cm, otherwise a flawless fit. 150 more CCA and 15 more Amp hrs. |
8th May 2013 6:11am |
