Home > Td5 > Defender Cruise Control The guide they didn't want you 2 see |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 |
I have finally cracked how to get my 2001 Td5 Defender with the MSB ECU to have cruise control....
So there are people out there selling their special cruise control units specific to the defender, however this is not true... The box most people use is called the AP900 made by a company called Lite On based in taiwan... This box is so generic it covers almost every car with a fly by wire throttle system.... The only "special adaptation" that the companies over here have made is a special loom for the throttle pedal.. but that great an all, but when you still have to splice wires into the brake light, speed signal and clutch switch assembly. So you dont even really need the special loom. I was lucky enough to purchase my cruise control through ebay for a mere £28 nothing like the £450 odd quid you are always quoted. http://www.ebay.co.uk/itm/151005070753?ssP...1439.l2649 As you can see this was from a VW loom but yet it still works on the defender??? funny that>??? I will create a step by step guide tomorrow so that anyone who purchases a generic cruise control system can install it themselves and save a stack load of money... I have just managed to get it working tonight with no problems!! |
20th Mar 2013 8:41pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6036 |
ooh very interesting.
keep us posted. |
20th Mar 2013 10:10pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
What a great post to grab someone's attention
Very interested too |
20th Mar 2013 10:21pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
It is even much more simple!
Just some wire and switches, and use the build-in cruise control in the ECU. The plug on top is the black plug on the ECU under the seat. The pins on the ECU will be connected the following way: Pin 10 - Ignition +12V Pin 11 - Switch 1 (Set function) Pin 15 - ignition +12V Pin 17 - Switch 2 (Resume function) Pin 19 - is only mentioned, so you can connect here the available TD5 tachometer, not used for the cruise control. The cruise control works by supplying ignition +12V to pin 10/15 permanently and the functions are activated by supplying the same temporary to pin 11 or 17. For getting the ignition switched +12V (Zündplus 15), use the green/white cable at the temperature or fuel gauge in the dash. Put two switches on the dash and run a long cable to the ECU. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
20th Mar 2013 10:26pm |
Sorry, missed that... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
20th Mar 2013 10:51pm |
This is what I have done thus far... pretty much the bones of it are there....
will put some more pictures in it tomorrow and update it but for the eager ones have a look at this https://skydrive.live.com/?cid=3824FB2FC74...E9EA%21107 |
20th Mar 2013 11:51pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 711 |
Have replied to your pm chinnus but it hasn't left my outbox.
21st Mar 2013 6:03pm |
