Home > Puma (Tdci) > Foam inner door card |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
called a water shedder mate CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
17th Mar 2013 6:06pm |
Front RH door is - EJD500620 £8.22
Front LH door is - EJD500630 £8.22 110 Mid row RH is ELD500400 £7.48 110 Mid row LH is ELD500410 £7.48 CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
17th Mar 2013 6:08pm |
Delskinz Member Since: 18 May 2012 Location: North Devon Posts: 84 |
Cheers buddy!
I will have dry truck...I will |
17th Mar 2013 6:39pm |
clever how they work really as all the water goes down them and out the bottom check your bottom door sills as they can sometimes keep the water in there CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
17th Mar 2013 6:42pm |
Looking at FCX's new 130 he's put Dynamat under the door card. Would it work as a water shedder too?
17th Mar 2013 10:50pm |
Yer would work the same, the Dynaliner looks very similar aswell to the Genuine foam. CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
17th Mar 2013 11:23pm |
I see a plan forming.......mwhahahaha
Thanks again for the advice! |
17th Mar 2013 11:32pm |
excuse to get some dynamat i suppose CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
17th Mar 2013 11:35pm |
Just replaced the water shedder which was letting in water behind the door card and on to the rear carpets.
This was "the before"picture - the bodged tape work looks like it was original out of the factory , taking the door card off there was no sign of previous access to behind the card (plastic studs were perfect, the lock shroud was a pig to get off, screw heads looked good etc etc). Click image to enlarge |
20th Mar 2013 2:42pm |
Following a night of heavy rain...............NO LEAKS!!!
If anyone is struggling to find a mystery water leak take a look at this, for an £8 repair its worth checking. |
21st Mar 2013 9:30am |
