Home > Puma (Tdci) > gearbox bottom fixing
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I was underneath the puma installing the cabling of my winch when I noticed that it seems there is a missing mount on the bottom of the gearbox. The hole with screw thread is in the gearbox with a space to mount on the chassis directly underneath. But nothing is there.....is thus normal?
Post #219620 16th Mar 2013 6:46pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Yes its normal, you can check the other 2,000,000 posts on google about the subject. Whistle Don't worry, every Puma owner has asked the same question! Wink
Post #219621 16th Mar 2013 6:49pm
ZeDefender
I wonder if the 2.2 raises the same question? Tell someone you love them today because life is short.
Post #219633 16th Mar 2013 7:12pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi Ze, I can confirm it does, my new 2.2 has the bracket and the tapped hole in the gearbox but no mounting in between. Info I got from somewhere, either on this site or from the dealer was that they stopped fitting the mounting circa 2008/9 as it was found that either the mounting coroded/stripped the gearbox threads and/or caused cracking of the gearbox so they stopped using it. You'd think by now they would have stopped having the bracket on the chassis.
I wondered if maybe some people like rally guys might still use the mounting for heavy duty use?
Cheers, John.
Post #223336 29th Mar 2013 11:11pm
There has never been a mounting fitted here.
Post #223340 29th Mar 2013 11:52pm
ZeDefender
Aahh - but maybe with the new Hyundai drivetrain Confused Tell someone you love them today because life is short.
Post #223363 30th Mar 2013 7:56am
Happyoldgit
Cheers, John.
There was never an actual mount bush fitted between the bracket in question and the box, at least not on any I've seen including the early Puma I bought new in '07. Steve.
http://forums.lr4x4.com
Post #223420 30th Mar 2013 12:16pm
ARC99
Not the information given to me by my local LR garage, he has had problems with pre 2007 Defenders fitted with a rubber mounting at that location. I have never known him to tell untruths before but this may be the first time I don't know.
Post #223422 30th Mar 2013 12:33pm
ibexman
. Was never fitted
Post #223423 30th Mar 2013 12:37pm
Happyoldgit
There are perhaps a dozen or more threads on this forum alone querying the bracket, tapped hole in the transmission and lack of mount between the two on Puma's. Pre 2007 Defenders did not have the phantom mount on the bottom of the transmission either I'm afraid. Steve.
Post #223447 30th Mar 2013 3:27pm
