Home > In Car Electronics > Original OEM Alpine Subwoofer - Pictures required
DXB90
2013 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Hi All,
Trying to locate some pictures of how this is attached from the factory to the back of the cubby box. Microcat shows three parts.
1. Subwoofer
2. Plate
3. 4 x Nyloc Nut
But in my 2013 X-Tech 90 the inside of the cubby box has no holes or marks to attach.
Anyone with a factory upgraded one would appreciated pictures of inside and outside the cubby and also how the cabling/power is run.
Tim
Post #218348 12th Mar 2013 4:40pm
DXB90
No one????
Post #219966 17th Mar 2013 7:08pm
buellbeast
2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
I have one ill take some pics tomorrow although I don't think I saw any mountings inside the cubby box, unless they mount it with countersunk fittings and then trim it
Post #219980 17th Mar 2013 8:02pm
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
the wires all run outside the box just the plate is located inside the box and the amp is bolted to the plate from the outside the wires i believe run under the cubby.
hope this is helpfull
Post #219981 17th Mar 2013 8:05pm
rich
also the cubby with the sub attatched is an inch or so shorter than the standard one without, there is nothing special to how they have fitted it just drilled holes through the trim, box and interior card thats it
Post #219984 17th Mar 2013 8:14pm
DXB90
Thanks Rich Thumbs Up any pictures? .As trying to mount one in my X-tech when the sub arrives from the UK. Seems that the pre-wiring is in place already underneath the cubby and that microcat shows the sub with a trailing wire. Do you think they modify the hight of the cubby? The X-tech has a bigger pad on the top so I don't think that will cause any issues.
Post #219988 17th Mar 2013 8:26pm
DXB90
Thanks buellbeast Thumbs Up
Post #219989 17th Mar 2013 8:27pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
not sure if this helps but i put an Alpine sub on the back of the cubby box.
 BM52
Post #219993 17th Mar 2013 8:32pm
rich
there is no difference in height at all just length if i have one at work ill get you some pics aswell, cant be 100% sure if we have one in
Post #219994 17th Mar 2013 8:32pm
DXB90
Rich, got you, where do they shorten the 'cubby hole' presume it as a different pad too? Is this in microcat?
Post #219999 17th Mar 2013 8:49pm
rich
the whole cubby box is shorter from front to back, they have taken an inch or a little bit more off the front section where the slope is, its at a steeper angle now, i have got one of each i can take pics of to show you ill post them tomorrow.
the plate for the inside has 4 threaded bars that will show through the back of the cubby that the sub will fix to, i can get some measurements for the holes when i take the pics.
Post #220002 17th Mar 2013 9:02pm
DXB90
Thumbs Up rich guessing no microcat part just modification?
Post #220004 17th Mar 2013 9:04pm
rich
there must be a new part number its not just chopped, the new microcat disc has arrived so ill take a look at it and see if there is a part no for the new box for you also
Post #220005 17th Mar 2013 9:06pm
DXB90
Cheers rich Thumbs Up
Post #220008 17th Mar 2013 9:15pm
rich
send me your email by pm DXB90 and ill send all these pics and hole positions for you.
and yes there is a part no for the new cubby but not sure if it comes with the sub it is in the description and it cost £215 to us if i remembered the price correctly obviously plus vat
Post #220259 18th Mar 2013 7:59pm
