Home > Td5 > Alarm and central locking problem |
Anyone
18th Sep 2009 6:04pm |
Was it that way from the start or suddenly?
I believe the dealer can switch it on and off. I know he can switch the immobiliser off. Or you can do it yourselves with a faultmate or something like that. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
19th Sep 2009 9:39am |
We only just got the landy and the fault was allready there and stupidly i thought it would be an easy fix
19th Sep 2009 9:58am |
It could be an easy fix if nothing is wrong. But then why did they switch it off? Roel
19th Sep 2009 12:59pm |
Ok i'm an idiot i went through everything again today and found a fuse i missed so it now works (apart from the drivers door which i think is the solonoid) so thanks for the advice
Ray |
19th Sep 2009 1:05pm |
That's even better. Roel
19th Sep 2009 1:09pm |
Yes it's great but i do still have a wiper problem where there is no intermitent and they won't park in the right place and for some reason the horn only works off the rear window wash button do you know where the earth points for these are before i pull everything to bits
Cheers Ray |
19th Sep 2009 1:13pm |
Have a look here:
http://green-oval.com/joomla/index.php?opt...;Itemid=29 What you want is de CD-2 defender. It is very usefull. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
19th Sep 2009 1:40pm |
