Home > Maintenance & Modifications > MUD DEFENDER ROOF CONSOLE |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Thinking if getting this as need to put the CB radio somewhere
Anyone know how deep the DIN is as I don't really want to be cutting into the headlining ( not even too keen to drill into the door surrounds) |
10th May 2014 5:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5408 |
Am sure some CB's will fit without a cut. My current cb is din sized but much more shallow than a radio head unit and the tti unit I had before was smaller than din. When I spoke to mud, I think they said most CB's would be ok.
Andy |
10th May 2014 5:30pm |
Thanks Landyandy
My CB is 17.5 cms (18.5 cms as need to allow for the SO239 socket) I'm still undecided about whether to mount on front of cubby ( and remove when not in use) or get the roof console for a more permanent fitting |
10th May 2014 5:41pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I doubt it will fit without cutting the headlining.
I've got a basic Maxon CM10 which is 180mm deep and needed to cut the headlining. I don't see an issue with cutting a small hole in the headlining if the roof console is never going to be removed again. You can't see it. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
12th May 2014 10:11am |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
I also agree that you would, more then likely, have to cut away the headlining. I had to for my CB and that's quite small .
Do you have a standard cubby? If so, have you considered changing it for one that accepts a radio - Mobile Storage Systems, FCX for example? May be a lot easier than an overhead console..... I have an MSS one and would recommend that. Tony |
12th May 2014 12:14pm |
Patrikj Member Since: 12 May 2014 Location: Gothenburg Posts: 2 |
munch90, when you'd cut the center "bars" of the Mud console, did the shelf get unstable/weak ?
/ Patrik Last edited by Patrikj on 13th May 2014 2:18pm. Edited 1 time in total |
12th May 2014 2:13pm |
no shelf seems much the same as before
12th May 2014 2:20pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Thanks kzycnn
We have two cubbys in the range that have DIN sized slots for a CB This one actually has two DIN slots, one with a secure 'slide away' cover [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] and this single DIN [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
12th May 2014 2:22pm |
Ah that cubby looks great FCX
Sadly I have an LR cubby - is there a trade in value for that |
12th May 2014 2:58pm |
Sure, we'll give you £40 for your standard cubby with cup holder in good nick
12th May 2014 3:01pm |
That's a good offer. Still cannot justify the spend on one of those. Lovely though
12th May 2014 7:54pm |
No worries
12th May 2014 7:55pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Just as a FYi should you need a new screen you will (may) have to remove the visors and the three (each side) capped screws so the front of the console gives clearance for the screen rubber to be refitted
29th May 2014 1:52pm |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 253 |
New screen Ken? My Disco 'best bits'
Defender 110 XS CSW 2013 |
29th May 2014 5:42pm |
