Home > Puma (Tdci) > Alarm LED in dash flashing whilst driving
Page 2 of 3 <123>
AdvTim
borderterrier wrote:
SGoggin wrote:
In the My12 tech reference manual, it mentions that if the alarm light flashes whilst driving it indicates that the key fob in use has a low battery and this needs to be replaced.
"If the remote handset battery falls below a pre-determined level, the handset will transmit an additional RF signal code to the anti-theft system module. This signal is relayed to the instrument cluster indicator which emits 2 rapid flashes every 0.5 seconds to inform the driver that the remote handset battery needs replacing."
If mine flashed with that frequency, 2 rapid flashes every 0.5 seconds, I would be happy as clearly its meant to do it. Mine is more like a loose connection and comes on when it feels like it!
Steve
Yep mine is a random pattern and timeline.
Seem to have now isolated mine down to having my iPhone charging from the lighter socket, think the Bluetooth was a red herring as phone was always plugged in and charging.
Post #205062 24th Jan 2013 8:58pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Will try that tomorrow.
Steve
Post #205122 25th Jan 2013 12:08am
WWA
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Orkney Grey
I shall also try that
Post #205138 25th Jan 2013 8:22am
borderterrier
Didnt come on at all, but driving tonight the light flashed once over a 120 mile journey, so it really is random.
Steve
Post #206949 30th Jan 2013 9:59pm
AdvTim
Steve
I can go a whole journey with it not flashing or flashing once if I have the radio on and the phone not plugged into the lighter socket.
As soon as I do plug the phone in I get a double flash then it might behave for as much as 30 minutes before the light show begins
Post #207100 31st Jan 2013 4:56pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
mine is one long flash (1 or 2 seconds long) and it only is once in a blue moon.
Post #207157 31st Jan 2013 8:01pm
SGoggin
Mine started doing this - and I can now reproduce the random flashing. It seems to occur only in the underground car park at the local shopping center - so I reckon it must be picking up some external interference from either another vehicle, or perhaps in the shopping center itself.
Post #231906 1st May 2013 5:32am
chadjizz
mine is the same, it does it everytime i go past a certain point on a local road to me, the slower i am going the more (3 max) flashes i get...!
Post #232054 1st May 2013 5:52pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Same on mine. Randomly, alhthough, somehow I get the idea if it lights up for a second, it's usually when I'm slowing down for the slow corners. Confused
Can't imagine the battery will be low as I have the car for less than 2 months.
Post #232056 1st May 2013 5:57pm
borderterrier
Hey Landrover, if you are monitoring the sites please look into this. Something must be causing it!
Post #232102 1st May 2013 9:19pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Mine also does totally randomly and generally flashes very quick but tonight it stays lit for a few seconds. Has anybody made any progress finding a cause?
Post #245475 21st Jun 2013 10:33pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Mine does the same my13
Swapped fob battery seems ok
Post #245476 21st Jun 2013 10:39pm
sweepc
[quote="Cakey"]Mine does the same my13
Swapped fob battery seems ok[/quote]
Thanks Cakey ill swap the battery tomorrow and see how it goes!
Post #245477 21st Jun 2013 10:41pm
tookaphotoof
The Defender will be off to the dealer coming Monday to get a part changed. Haven't asked what it was, but I'll let you know if they get this problem solved.
Have to say, I didn't really mind the light flashing once in a while, but as the Defender is under warranty, I might as well get it fixed. Mr. Green
Post #245515 22nd Jun 2013 9:52am
Morepower
New Zealand
Mine did this the other day too.. One long flash (around one second).. Just long enough for you to go "what was that?"... Mine is also a 2.2 13my Defender. It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #245561 22nd Jun 2013 2:29pm
Page 2 of 3 <123>
