Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Hi, I don't have any pics of mine as I didn't take any while doing it most others as above had plates made up to put in and cut out the old panel but as I have a panel beater background decided to re shape the existing panels Ray
21st Feb 2017 5:39pm |
Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89 |
Did you use the side supports then or have you just made the clearance in the arch
21st Feb 2017 8:17pm |
I haven't used the side supports yet but do intend to when I get around to fitting them. The seats have been in for a couple of years now without the supports and I've had no problems yet but just for peace of mind I will fit them eventually. Ray
21st Feb 2017 8:27pm |
Thanks for the reply, just emailed yrm see if they fancy doing some plates
21st Feb 2017 9:28pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Yes, this is my truck. The inserts are 2 pieces, then seam sealed and rivered in place. There are a couple of awkward bends in there, used a small vice brake to do the bends. Primed, painted then installed. I added the support brackets once the seats are in. The set up is pretty solid. Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
21st Feb 2017 10:36pm |
the whole car needs a good de fumigating as its filthy inside and out I've got a big job to finish in the next month or two then go to town on it Ray
12th Mar 2017 6:46pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1749 |
H mmmmmmm, that sounds like a task for ...............
12th Mar 2017 7:49pm |
dun dun dun...... Superjez!!! Ray
12th Mar 2017 8:47pm |
Finally got a few mins to put the rear door guard on, I'll keep it on until I put the new rear door on then decide if I want it on permanently or not
Click image to enlarge Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
2nd Apr 2017 1:04pm |
An expensive day
Click image to enlarge Downside is it hasn't solved my problem Ray My build thread http://www.defender2.net/forum/topic17615.html |
26th Apr 2017 6:25pm |
What's the problem Ray? (Obviosly not the injectors ) 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Apr 2017 8:18pm |
Lots of black smoke I've been told before that an injector sounds like it was dragging so we thought over fuelling from a leaking injector but apparently not. What's worse is there's a knock after replacing the injectors so I'm not sure what to do now. Ray
26th Apr 2017 11:05pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
Oh dear Ray
Did you get any further with programming the injectors ? If all else fails get some rigger boots, bush hat and a "NO SMOKE NO POKE" sticker |
27th Apr 2017 8:15am |
I was thinking more along the lines of can of petrol and a match the nanocom may have come up trumps with some info on cylinder balance so it's going back to the garage tomorrow for one of the injectors swapping back to rule it out. Fingers crossed Ray
27th Apr 2017 10:33am |
