Home > Puma (Tdci) > Transfer Box Leak |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 |
Hi Taff
You have obviously never removed a LR gearbox Actually, my local dealer just did the seal on my TD5, they had it in overnight and I picked it up next day FOC as the recon box was less than 12 months old that they fitted under warranty. I would assume that they will probably just remmovethe transfer box from the back of the main box, but remember that means removing propshafts, disconnecting handbrake, possibly remove exhaust, any under body protection, drain the tb, then remove that. Then of course there is the reassemby too. He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
31st Dec 2012 11:32am |
adiep Member Since: 18 Nov 2012 Location: Gibraltar Posts: 204 |
same problem Taff, can you let us know what you are quoted to fix it please. |
31st Dec 2012 9:37pm |
Should not cost a penny, falls under warranty for a 2012 car. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
31st Dec 2012 10:23pm |
Ah yes, the OP has a 2012... mine is a 2008 unfortunately ! |
31st Dec 2012 10:26pm |
Taff Member Since: 28 Dec 2012 Location: Bath Posts: 16 |
This is the first one I have ever owned with a warranty. Have driven ones in Kenya but it did not matter what leaked out of them. Will keep you posted. Getting work done in a week or so.
31st Dec 2012 10:59pm |
cheers Taff.
31st Dec 2012 11:12pm |
Hi adiep, mine is a 2006 TD5 with extended warranty, do you still have extended warranty? if so try them. When I bought it 18 months ago from the dealer it came with the warranty and after I complained about finding it hard to engage 3rd and reverse they agreed and changed the box with no quibble. It was only last October I noticed drops of oil on thedrive and after crawling underneath found the bottom of the transfer case coverred in EP90. Fortunatly I had just extended the warranty again (£460 a year) which I was was sceptical about at the time but in th case if the transfer oil seal I think paid for it self. So if you have any warranty left try the dealer. They will warn you that they charge you for an investigation, but that is waived if it is coverred under warranty. He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
1st Jan 2013 1:52pm |
