Home > Puma (Tdci) > Heated screen switch |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 |
My light stays on for 3 seconds -assume there is a timer module mounted somewhere? Can anyone shed light on this for me?
Thanks, Tom |
11th Dec 2012 10:26am |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
I assume you are talking about front screen? mine stays on for about 5 minutes, back one will stay on until it's switched off
11th Dec 2012 10:29am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7704 |
should stay on 10-12mins IIRC Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Dec 2012 12:11pm |
Thanks for the wiring diagram... I assume this is all under the drivers seat, will take a look. I assume the timer has failed completely. Will post the results.
11th Dec 2012 1:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16901 |
The timer relay (as well as the main screen relay) are under the RH seat.
The timer relay will be deactivated if you press the switch whilst the screen is heating, or if you switch off the engine. Assuming that neither of these is happening, a short ON cycle probably indicates either a defective timer or a loose connection. |
11th Dec 2012 2:05pm |
Relay is clicking away quite happily. Have removed timer and can't read continuity between any of the pins. I assume it's duff?
11th Dec 2012 5:56pm |
The timer relay is all-electronic inside (not a conventional relay in any sense of the word) and I suspect that the only easy way to test it is to swap with a known working one.
11th Dec 2012 6:56pm |
. Don't know anyone with one and the cheapest I can see is about 70 quid! I'll look for a non LR timing relay.
11th Dec 2012 7:32pm |
I think Vehicle Wiring Products sells a range of pin-compatible timer relays at sensible prices. I bought one from there for use with my heated mirror upgrade.
11th Dec 2012 11:59pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6486 |
If used is OK they turn up on eBay, like this one: http://www.ebay.co.uk/itm/Range-Rover-Clas...0957438906
Part number PRC6796 1988 90 Td5 NAS soft top 2015 D90 XS SW |
12th Dec 2012 12:53am |
