Home > Puma (Tdci) > Rust Proofing Underside |
adiep Member Since: 18 Nov 2012 Location: Gibraltar Posts: 204 |
Hi Guys, ive read through the sticky on the maintenance page but have some questions, so thought i would ask here.
On the underside of the car, there are engine parts, nuts and bolts with threads exposed, body parts (floor) and suspension springs, brakes and of course chassis. Out of that lot, what should be waxoyl'd? If i paint over bolt threads, wont it be difficult to get them off next time? Also, where the car floor is visible from below, should I spray that too? I am presuming the chassis is the main place i should be spraying? Also, how are you guys doing this spraying. are you just using spray cans or buying spray guns I live in a hot climate, so rust is less of an issue, but would like to take care of it all the same ! |
11th Dec 2012 8:27am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Invite Zag over for a holiday! He could sail to you now.
I used Dinol and did EVERYTHING even some things I didn't mean to do. Compressor and a shutz gun, masked the brakes and exhaust, cavity wax inside the box sections, black wax everywhere else. Mucky but fun. Keith |
11th Dec 2012 8:36am |
Well, looks like local tool hire shop has everything i could ever need apart from a spray gun. this one look any good? Sealey SG18 Air Operated Wax Injector Kit http://www.toolbox.co.uk/sealey-sg18-air-operated-wax-6603-106243 |
11th Dec 2012 11:16am |
Yes that will be fine. Steve.
11th Dec 2012 3:08pm |
Do a search on the net and other forums as rustproofing Land Rovers has been one of the most widely covered subjects over the years, certainly longer than some experts have been around. Steve.
11th Dec 2012 3:10pm |
Thanks guys, I think I have an idea of what to do now and how to do it appreciated.
11th Dec 2012 9:39pm |
