Home > Puma (Tdci) > SVX off set |
WWA Member Since: 12 Aug 2012 Location: Northumberland Posts: 197 |
Do SVX alloys have a different off set to boosts as stated here... http://funrover.com/featured/defender-wheel-options/
If so, is it much? |
9th Dec 2012 3:40pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 656 |
I'll check for you later as I have both sitting in the garage.
Cheers Steve |
9th Dec 2012 3:46pm |
That would be great. Thank you
9th Dec 2012 3:49pm |
Also forgot to add that load rating on boosts is 1050kg, and 1000kg on SVX
9th Dec 2012 5:26pm |
Thank you taking time to do that. I thought they would be the same. Cheers Steve
9th Dec 2012 6:00pm |
nick67 Member Since: 12 Nov 2012 Location: Timisoara Posts: 6 |
The original offset for Alu wheels is +38 mm for SVX. Defender SVX 2008
Discovery 3 HSE 2005 Discovery 1 300Tdi 1995 |
9th Dec 2012 7:01pm |
I looked again it's marked up as 33 on the alloys. This would account for me measuring from back of alloy for backspace, not using inside rim width.
Cheers Steve |
9th Dec 2012 7:37pm |
So they are still the same or has the SVX different??
9th Dec 2012 7:38pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Has to be wrong....... Why would you make a special edition wheel that sits even further into the arches?...... It would look terrible and you would have even worse steering lock!! Glyn |
9th Dec 2012 7:41pm |
They measured the same, both are original LR wheels so they are the same. |
9th Dec 2012 7:48pm |
Thank you Steve. They even look the same on pictures, was just that website that threw me off. They still look the nuts though
10th Dec 2012 8:30am |
