Home > Tdi > vibration
Page 2 of 2 <12
Shutts
United Kingdom 1995 Defender 90 300 Tdi SW Arles Blue
Guys, interesting discussion. I notice in the article it relates to range rovers and 110s. Is this the same for 90s?
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
()_)' '()_)-----()_)
2005 D3 SE
1998 Disco 300tdi - slow play thing
1995 Defender 300tdi - Winching play thing
Aprilia RSV 1000 - fast play thing
Honda CR250 - noisy play thing
Essex Land Rover Club member
Andy's Landy's - http://www.andys-landys.blogspot.com
Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip
Post #585196 14th Dec 2016 11:56pm
Retroanaconda
Yes, all RRC/Disco 1/90/110/Defender up to and including Td5 have a front prop out of phase.
With Tdci onwards I believe it changed due to the drivetrain inclination required to bodge the Transit engine in. Not sure what the effect was but I suspect it may mean both props are out of phase?
That article is wrong in its assertion that the out of phase front props are not mentioned in the workshop manual, seems pretty clear here:
Post #585538 16th Dec 2016 10:39am
Shutts
Just checked and my ones were in phase. Pulled the prop off and replaced a UJ as it had a small amount of play. One thing though, there are no alignment marks. Are thexpected joints 90 deg out off phase or a small amount as described in the article?
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #585820 17th Dec 2016 6:19pm
Shutts
Did a check on the web through Google images and looks like its 45% out of phase so set it to that. Going to give it a run tomorrow to see if it sorts the issue.
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #585863 17th Dec 2016 8:16pm
Shutts
Just to provide an update. The change made some difference but it was still not 100% perfect. A few months later I swapped the front prop for a Discovery double cardon one and it made the world of difference. Would recommend this mod to anyone.
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #769031 17th Apr 2019 10:12pm
Page 2 of 2 <12
