![]() | Home > Puma (Tdci) > Inside my Defender........AKA new clutch installed |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Gearbox complete:
Click image to enlarge Old Clutch disk, see the spring head.... Click image to enlarge Again Click image to enlarge New clutch disk Click image to enlarge Flywheel (like new 22.500 km Click image to enlarge New clutch box with code (I checked it's the last revision) Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Yes, new spring materials (new color code).
Like you can see, the friction material and the flywheel are in perfect condition. You must now that my engine was remapped and it produce 47kmg of torque (480Nm). Bench tested....... |
This morning I just drove for 489 km................
all ok................... |
| mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286
What symptoms caused the replacement(s)?
loud rattle at the engine switch on or off (without pressing the clutch)
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114
dgardel,
Good to see that you have a new clutch installed. In mine, one of the springs went out completely leaving us in the middle of a rural road in the night with all the family inside. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672
did you have any laboured rattles in 6th under load??
No, no rattle at all
