Home > Tdi > Ashtray hole size |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
Good idea,
Andy |
9th Oct 2012 8:49pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
It reminded me of this
http://www.mudstuff.co.uk/shop/161-defende...-tray.html |
9th Oct 2012 8:55pm |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
That is a genius idea Andy, any idea who makes the mount or is it homemade?
Thanks, Mark |
9th Oct 2012 11:24pm |
kevb Member Since: 03 Apr 2012 Location: AllPackedUp Posts: 34 |
Hiya Mark, have you seen Ram Mounts? its a modular system so you buy what you want/need. I have a suction cup mount for my 276c sticks on to the windscreen so it fits any vehicle, you could also use a flat plate mount screwed on to the ashtray. i thought of this but decided a suction cup would be more secure.
Maybe not the cheapest solution but the quality is there.... and you being an expat & all...... I would post a photo but like you, mine is far far away http://www.ram-mount.co.uk/garmin-gpsmap-1...-1393.html http://www.ram-mount.co.uk/1-ball-round-ba...8_286.html http://www.ram-mount.co.uk/double-socket-a...8_286.html |
10th Oct 2012 12:04pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6487 |
Also available from any LR dealer/parts supplier under part number FDT500040PMA 1988 90 Td5 NAS soft top 2015 D90 XS SW |
10th Oct 2012 1:07pm |
Hi Kev,
Yep i have seen the Ram mounts, but i had forgotten the name of them, so thank you for reminding me. Yep as an expat i am well and truly skint mate! Regards, Mark |
10th Oct 2012 3:40pm |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 |
Great job Andy
That just inspired me to get out the useless phone holder I already have on which the sucker refuses to work, a 2mm drill bit and "Hey Presto!!" Obviously as I am using the phone to take the photos I cannot show it in situe, however now I can easilly use it for Co-Pilot SatNav. Click image to enlarge Click image to enlarge A little more fettling and it should be just perfect |
11th Oct 2012 12:49pm |
Does anyone have the dimensions please?
Thanks, Mark |
14th Oct 2012 6:34pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 421 |
Hi Mark - just measured my td5 - assume they are the same ??
internal hole measurements are - 55mm x 110mm with rounded corners Hope that helps |
14th Oct 2012 8:38pm |
Thank you Gavin,
Obviously there will probably be the usual Land Rover tolerances, but it gives me a starting point to make my mount for the GPS. |
14th Oct 2012 8:47pm |
