Home > Maintenance & Modifications > Pro Comp Extreme Alloys |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Chaps,
Can any of you lot get these and ship to the uk? http://www.quadratec.com/products/92819_27XX_A_PG.htm Alex E had a similar set on his 110dc and thought they would look pretty good and different on my 110 By the way does anybody know what the stud pattern is for a 110? You cannot teach stupid people to do clever things |
9th Jul 2009 10:44pm |
They dont do them anymore You cannot teach stupid people to do clever things
10th Jul 2009 11:02am |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 |
SOoooooo last season....
Click image to enlarge you can also get 18" ones too.... |
10th Jul 2009 11:33am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2262 |
Bolt pattern is 5 on 6.5. Puma 110" SW ............................................................. Earth first. Other planets later |
10th Jul 2009 1:02pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Hi All,
I know "Holy Thread Resurrection Batman" ... However, I'm after some help. I have a set of these wheels on a recently acquired 110 DC (but the cast black version), but there's a right royal mix of wheel nuts and one missing though found the spare, but I think the hub thread is damaged as it wont bite. I'm trying to source a set of fresh nuts *cough* but really struggling. I have contacted Pro Comp and they say they don't do them! ... Well, they seem to be attached to my truck rather well if they don't! Does anyone know anywhere I can source some? (Also tried Craddocks) Or does anyone know the correct dimensions? Obviously they'll run M16 x 1.5, but I cant be certain on the seat taper. I've very roughly measured the spare and I believe it to be 60*, but for M16, the most common taper is 80* with no where really having a 60* taper on that size. I've found a source of U.S. Wheel nuts which fit the bill, but the tapered section doesn't half as meaty as the Pro Comp ones so not sure what to do. Plus I'm still not 100% on the taper degree. Is there a way to find on on the wheel, which taper it runs (Cant get my angle ruler in the hole)? Many thanks in advance and sorry again for bringing back from the dead! On a side note, does a 0 Offset really equal roughly 4.5" spacers :O!? |
8th May 2014 11:38am |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
Quadtech ship to the uk, I have had a steering damper sent for a wrangler.
8th May 2014 7:40pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 513 |
@ taaz 00 offset is the same as a 33mm spacer - as std LR rims have 33 offset (Boost, Freestyle or std steels - Wolf are 20.8
8th May 2014 7:44pm |
Can't find any reference to a Quadtech unless about Quad Bikes :p!?
Do they have the right nuts? Been talking to the Pro Comp guy again today and he's sure pro-comp never made the nuts for thye Defender so he says they must of been supplied by someone else. Summit Racing have a US Wheel, lug nut with the correct dimensions, they just dont look very solid. The taper is built into the Hex if you get me, unlike the ones I have now which had the tapered section, then cut down to the Hex, so look much stronger. As to the offset, that's good to know! Always though standard was more, but now stand corrected . |
8th May 2014 9:38pm |
Try these, if they don't have them they'll make them.
http://www.wrington.co.uk/index.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th May 2014 10:46pm |
