Home > Puma (Tdci) > MT82 Gearbox Breather |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Erm it won't be easy but on a defender it is about 8-10 inch long and at the closest point to the engine it just pushes into a hole so it breathes into the bell housing
On the gearbox I'm using with my 3.2 engine it came with a breather from the gearbox that goes straight up to the. Front of he engine I think if you can do it which you can I managed to before pull it out from the hole and uses a 6mm connector and make it longer If that's what your intentions are Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
20th Sep 2012 1:06pm |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
Thanks Steve - any ideas about how the other end is attached? And could I get in there to remove it and refit later?
I need to check it's not blocked as I have oil blowing by the filler plug. (I have the correct amount of oil) Thanks Mark |
20th Sep 2012 2:23pm |
Yerflat blade screwdriver under the black part and gently prize it out doubt it will be easy whilst it's in but should be possible
20th Sep 2012 2:24pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2266 |
I posted a pic showing it. Try the search button. Puma 110" SW
20th Sep 2012 4:36pm |
Hi MK, Tried a search but no luck. Can you give me the title of the thread you're referring to? Or a link? Many thanks, Mark |
20th Sep 2012 5:25pm |
Item nr. 6
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
20th Sep 2012 6:16pm |
