I have had a 2007 90 and the head lights were as bright as a candle so im looking to upgrade my 2012 90 head lights but thought i would ask the guys in the know, in what bulbs you would go for, but i dont want to have to change the wires etc?
I have rally bulbs in my last one from Halfrauds but they dont seem to do them anymore 110/90w
Stu
Pay attention about the possibility of burn the headlamp switch. All the headlamps current pass through the switch.
if you install the 110/90W bulbs, you need to install a relay also.
The switch (position HEADLAMPS ON) will drive a master relay for the headlamps main power.
Do a search on the forums, you will look for the electrical scheme modification......Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
