Home > Technical > abs tc |
Question must be asked having run with the lights intermittantly 'on' for the last two years are you really that bothered they've now gone 'out?'
In answer to your question the ABS block noise you hear when approaching a junction is not normal. I have TC and ABS and have sufferred issues myself. I know how frustrating it can be but had them sorted whilst the defect was apparent. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Sep 2012 8:27am |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
Is this on a TD5 or TDCI?
I had the ABS/TC light appear on my TD5 and it turned out to be a poor earth in the seat box. LR have 3 earth pins in the painted seat box and hope that it will earth to the chassis in some way. For me it was an easy fix, I ran a wire from the earth pins to the chassis and it was solved as easily as that. HTH Ben 2002 Defender 110 DC |
12th Sep 2012 8:49am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
I don't surpose you could post a picture of where these earth pins are.
Had a similar problem myslef. Will Defender 90 XS TD5 (03 Reg) |
12th Sep 2012 10:27am |
They are in the seat box under the drivers seat.
They are under the ECU I believe. 2002 Defender 110 DC |
12th Sep 2012 6:08pm |
This might help - the green circles show two of them in the floor of the seat box:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Sep 2012 6:50pm |
Excellent thanks a lot, will check them tomorrow
One last question. Do you know the location of the earths for the heated front screen? Will Defender 90 XS TD5 (03 Reg) |
12th Sep 2012 11:44pm |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
Hi, Where exactly the chassis part connect to? |
6th Nov 2015 7:23am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Just had the same problem.
Mine was a broken ring terminal on transfer box earth. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
6th Nov 2015 7:58am |
