Home > Maintenance & Modifications > Spot / fog light switches
boode
England 2003 Defender 90 Td5 HT Rutland Red
I need to switch on some spots and was going to buy the Front Fog switch for a Td5 dash - YUG000540LNF.
The price of the switch is now £49 - last year I bought one for about £8
The rear fog switch is still £9 - YUG000530LNF
Can I use this switch to turn on LED spots ?
Does anyone have a wiring diagram for this switch?
Many thanks
Gavin
Post #165673 31st Aug 2012 11:41pm
boode
Just found out that the front switch is a latching switch
The rear fog switch is a momentary on which switches an ECU connection
So I guess the answer is no I can not use the rear switch to control Spot Lights
Would the rear demist switch work ?
Any other ideas or do I have to spend the £50
Post #165710 1st Sep 2012 10:29am
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
What about
http://www.land-rover-parts-shop.com/en/ui...&stp=s
Part number AMR6104
It could then fit behind the wiper stalk like in the Tomb Raiders - mine is wired up so that when off, the spots are off, but when its on the spots only work with the main beam.
I can try and grab a photo if it makes it clearer Thumbs Up
Post #165717 1st Sep 2012 10:59am
boode
Thanks Alex
They would do the job
Is there enough room in the stalk for it to fit ? A photo would be good.
I like the fact that the genuine Land Rover part is £100 and the Allmakes is only £10
Post #165718 1st Sep 2012 11:05am
TR51
There you go... Thumbs Up
Looks like there is a fair bit of space still there (although it seems all LR's are made differently (!)).
The steering column has (by the looks of it) had a hole drilled through the plastic for the extra switch, but this is covered by the rubber grommet that comes with the switch
Post #165721 1st Sep 2012 11:35am
TR51
It may be worth a chat with Andrew @ Defender Bits as he seems to stock a similar item and may be able to help...
http://shop.defenderbits.co.uk/defender-li...-624-p.asp
Although my one only has 2 options (on/off) but the above are (sidelight,headlight/off) it would seem (!)
Post #165722 1st Sep 2012 11:40am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Hi Gavin,
What about a simple Carling switch? Devon 4x4 have them on the shelf.
Regards,
Mark
P.s. getting really excited about the Northern Lights trip now! Very Happy
Post #165735 1st Sep 2012 1:19pm
leeds
Carling switch are a different size.
We have some genuine switches down at our lockup.
Brendan
Post #165742 1st Sep 2012 1:53pm
PaulMc
Have a look at this - http://www.defender2.net/forum/post164854.html#164854
. Paul.
Post #165743 1st Sep 2012 1:55pm
boode
Brendan
Would a Carling switch fit in to the space for the electric windows - mine are wind up windows
Post #165754 1st Sep 2012 3:00pm
PaulMc
I found this picture of ARB Locker (Carling) switches, fitted into the electric windows switch positions -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #165759 1st Sep 2012 3:28pm
mobilecentre have a good selection of switches, some with indicator leds Thumbs Up
Post #165789 1st Sep 2012 5:44pm
That extra switch is available in 3 or 2 positions... 3 position for off/side/main beam, the 2 position ones were also used in early 90/110s for the rear fog lights, so the icon on the plastic "lever" bit is slightly different.
Post #165870 2nd Sep 2012 7:33am
