Home > Technical > Does anyone have a copy of this website in pdf
chinnus
2001 Defender 90 Td5 ST Coniston Green
Hi all,
I am trying to install central locking onto my td5 2001 90. Everywhere on the internet this guide is refrenced...
http://la7dja.org/defender/pictures/
http://la7dja.org/defender/cdl/
However the website is down
I wonder if anyone copied this guide and saved a copy?
many thanks
Tom Chinnery
Post #165546 31st Aug 2012 11:23am
chinnus
update
I have managed to find a cached copy however it does not have the pictures? can anyone help?
Post #165576 31st Aug 2012 2:29pm
Yes, I have it saved here.
PM me your email and i'll send it over.
Post #165589 31st Aug 2012 3:48pm
PaulMc
The email address of the website's owner (Espen S. Johnsen) is given as - espen@jupiter.td.org.uit.no
. Paul.
Post #165590 31st Aug 2012 4:00pm
Dobby
Post #165620 31st Aug 2012 6:46pm
Dobby
And in case that doesn't work.. or for future ref. here's the text. The pictures directory seems to be random pictures rather than CL though.
Quote:
Fitting Central Door Locking to a Defender
by Espen S. Johnsen
Central door locking is one of the features in modern cars that one really can't live without, especially after first having gotten used to it. Unfortunately my 2001 MY Defender isn't modern enough to be factory fitted with this. So an aftermarket installation was definitely needed.
There are quite a few CDL kits available which are especially marketed for the Defender, such as this one from a Dutch company called British 4x4. But I just ordered a general two door kit and an additional actuator for the rear door, from Abacus Car Alarms in the UK. Total price including shipping to Norway was £84.50, which is rather expensive, but these are very high quality actuators made by MES of Switzerland and can't really be compared to cheaper inferior kits.
Front door actuators
The first step in the process of installing the front door actuators is removing the door trim casing. How to do this isn't exactly obvious if one hasn't done it before, but with the help of the workshop manual it was quite easy. I first tried to remove the studs securing the panels in two of the corners without destroying them, but gave up and just drilled them out. New ones can easily be ordered through eBay
The most obvious and probably only feasible place to mount the actuators is in the lower aft corner of the door. This position is not very different from where Land Rover has put actuators in their factory installation, according to the workshop manual. The difference being that the doors in the factory installation has been modified to easily accompany actuators, while the older doors are not prepared for this.
To fix the actuators to the doors, I used the supplied brackets and also a couple of home made ones. I wasn't completely satisfied with this, as the actuators tend to move a bit in and out when operated. Adding an extra brackets didn't help much, but afterwards I realized that fixing the long brackets vertically at the bottom of the doors would probably work much better.
This is how the cable is fed from the door. It continues behind the moulding under the lower fascia and to the passenger compartment fuse-box.
Mounting of the control relay
I mounted the control relay on the plate holding the fuses, as can be seen in the picture. Power is currently taken directly from the battery, using a cable with fuse that the previous owner had installed for some other equipment (this Defender used to be a fire truck fitted with siren and flashing blue lights and was partly painted in red). But I plan to make a more permanent arrangement by adding an auxiliary fuse box to the right of the existing ones and drawing power from one of the fuse links under the right. Another option may be to connect the relay to the same fuse as the alarm ECU (the fuse should probably be upgraded to 20 amp).
Interfacing to the alarm
Apparently the alarm ECU fitted to the Defender does not have the ability to directly interface to CDL, even if the same unit is used in other models for this purpose. It is possible to buy third party devices that could be used to do this, but before doing that I decided make some further investigations.
Just connecting to the lock/unlock pins on the external connector (pins 2 and 3 on J2) did not work, as could be expected. But when I opened up the unit and studied the PCB, it became evident that a relay (probably a EP2-3L1S) needed to control door locks was missing. My guess was that this had been omitted to save a few bucks and for the same reason, the ASIC would be identical in all versions.
The CDL relay when installed, would be driven by an ULN2003. The outputs of this chip are open collector and capable of sinking up to 500mA each of inductive load without any external components. As my CDL relay is operated by pulling the control lines low, I saw no problem connecting it directly to the outputs of the ULN2003.
After having soldered in the necessary wires, mounted the alarm ECU back behind the instrument pack and connected it to the relay, it was time to give it a try. Except first having mixed the lock and unlock signals, it worked perfectly and have been doing so for many months now.
Alarm PCB with wires soldered inAlarm after modificationAlarm PCB with wires soldered inAlarm after modification.
Rear door
After having tested the front door installation for a couple of weeks, I went ahead and completed the system, by installing the actuator in the rear door.
For the 2002 MY Land Rover introduced a redesigned rear door which had among other improvements, provisions for electric door lock. The lock it self was also slightly modified for this. In advanced I had ordered one these new locks, thinking it would be easier to use than the existing. But I hadn't thought about the fact that the 2002 upgrade also included new lock barrels so that the ignition key could be used to lock the doors. Thus my old barrel didn't fit in the new lock, so I had to stick to the old.
This was probably just as good, as connecting the actuator rod to the lock turned out to be rather simple. It only involved drilling a hole through the knob meant for manual operation of the lock from inside. To mount the actuator I made a bracket of a galvanised "sieve plate" of the type very common in wooden house constructions in Norway.
I had to make a small cut in the trim panel for the rod. A custom made cover for the lock would also be needed, as the original does not fit any more because of the rod, but I haven't made that yet.
Finally the cable is fed from the door, down through the body, along the top of chassis, then through the firewall and into the passenger compartment fuse box.
Last modified 2006-10-19 21:08:35+02:00
Post #165621 31st Aug 2012 6:56pm
PaulMc
Have a look at this -
http://forum.landrovernet.com/showthread.p...ost1510901
I posted the complete article there, with pictures, back in June 2010
. Paul.
Post #166075 3rd Sep 2012 2:26am
chinnus
Thank You
Thank you guys for all the help diesel_jim managed to email me a full copy
many thanks
Post #166104 3rd Sep 2012 10:14am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
it's really easier to open the 10AS and solder the relay into it and tap out pin 2 and 3 to the locks.
no fumbling around with external central locking units. The defender has migrated, leaving the owner behind.
Post #178817 25th Oct 2012 4:57am
dgardel
Italy
LINK UPDATED
chinnus wrote:
Hi all,
many thanks
Tom Chinnery
http://1drv.ms/1s47kuH
folder "Older MY" Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #178837 25th Oct 2012 9:44am
PaulMc
Espen S. Johnsen's central locking article is back up Thumbs Up
Here - http://la7dja.org/defender/cdl/
With the fullsize pictures, here - http://la7dja.org/defender/pictures/
. Paul.
Post #362712 6th Oct 2014 8:21pm
Romadog
Buy the bulkhead loom for an XS on ebay for £100.
Cut out wiring for central locking and electic windows, fit into dashboar and bulkhead and use genuine actuators and looms on the doors.
Plug and play easier in the future ! Thumbs Up
Post #362938 7th Oct 2014 6:45pm
