Home > Puma (Tdci) > Front washer jet has dropped off
rick123
England 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi
Just noticed my front washer nozzle has disappeared leaving a small piece of it presumably bolted to the bulkhead.
Does any body know how to replace it, easily!?
Thanks
Post #163910 23rd Aug 2012 10:34am
landylad
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Firenze Red
Hi Rick
I haven't had the problem thankfully on the 2.2 but I did my 300Tdi a few months back and it was a pig! the washer nozzle is a single unit with the washer jets moulded to the threaded plastic bolt (with the water pipe connection done inside of the cab. The washer pipe is connected with a push fit and then some funky spring clip terminal.
The whole thing was then secured in place using a brass bold and washer and then re-funly clipped.
Just where in the build process they assemble this bit is unkown but judging by the amount of dash I had to rempove to fit it I am guessing it is quite early on !.
Some others were more lucky in that they must have had tiny fingers as they managed the whole process by only removing the ash tray in the top of the dash!
Coming back to the Puma I would imagine it may be possible to just remove the upper central part of the dash and then fiddle and Fa*t ar*se around with it from the small access.
It may be worth having a gander as the bit itself is only two pence 'apenny!
hope it helps
Thumbs Up Landy Mad
Defender 90 XS Puma 2.2TDci
Defender 90 300TDI pick up
Post #163921 23rd Aug 2012 11:44am
rick123
Thanks very much landylad I will give it a go!
Regards
Rick
Post #163923 23rd Aug 2012 11:50am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
On the Puma, I thought that the jet assembly simply pushed on (which is probably why yours has simply fallen off). This is of course as long as the spigot bit which goes through the bulkhead is till in place to push a replacement on to.
Pete
Post #163930 23rd Aug 2012 12:30pm
rick123
Thanks Peter I will have another look but it appears broken.
Rick
Post #163934 23rd Aug 2012 12:49pm
Happyoldgit
Old pre and post Puma problem, the outer part often cracks and falls off. Pre Puma's it's either dash top off or if you have access to small fingers it's possible to undo the retaining nut via the ashtray. Never had to do a Puma yet. Steve.
http://forums.lr4x4.com
Post #163941 23rd Aug 2012 1:09pm
JWL
Why not while you're at it buy 2 replacements and put them in the spare wiper holes(used to hand the wipers to the driving seat position), join them up to the existing washer pipe with a Tee piece and get some better washers for the screen.
Post #163943 23rd Aug 2012 1:23pm
WelshDefender
Wales
I have very small fingers and did mine through the ashtray hole. Very fiddly but can be done with a long nose pair of pliers. Hardest part for me was getting the pipe pushed back on. Much easier to remove top of dash if you do not have lots of patience and little fingers Rolling with laughter
Post #163944 23rd Aug 2012 1:28pm
Ninetenths
2007 Defender 110 Puma 2.4 XS CSW Java Black
Puma jet just pushes on Pimped black '07 Puma
Equally Pimped Black Pick up Truck
Rollin deep
Post #163971 23rd Aug 2012 4:04pm
rick123
I have ordered a new part for my Puma, it seemed to be in one piece but hopefully when I get it will come apart.There is a piece still protruding from the bulkhead. Thanks everyone for your help.
Regards
Rick
Post #163990 23rd Aug 2012 5:09pm
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Has anyone done that on a Puma already? How hard is it to get to the other hole, talking about LHD? Is it enough removing just the center console or the entire dash?
Got the additional jet at home, but I am far away from home for the next few weeks. So I am curious what I may face...
BR
Oskar
Post #164003 23rd Aug 2012 6:07pm
wslr
There is a part not on Microcat which the dealers tend to stock. It's simply a repair section for when there is still some of the original unit still in place like your has. You (and indeed they) tap this on over the top and 8 out of 10 times it actually stays there and works as good as new. I don't have the part number here at home, so you will have ask directly at a dealership parts counter.
Post #164070 23rd Aug 2012 10:31pm
rick123
Thanks WSIR I will check that out
Post #164084 24th Aug 2012 5:53am
Happyoldgit
As I said the outer bit [that contains the actual nozzles] often comes away Rolling Eyes Steve.
Post #164114 24th Aug 2012 9:39am
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
[quote="AlpenAndes"][quote="JWL"]Why not while you're at it buy 2 replacements and put them in the spare wiper holes(used to hand the wipers to the driving seat position), join them up to the existing washer pipe with a Tee piece and get some better washers for the screen.[/quote]
BR
Oskar[/quote]
I had done this on my Td5 and it was quite easy. Taking the whole dashboard apart was a matter of 6 screws or so. I have attempted to do the same on the Puma and I gave up. The dashboard is a nightmare and I haven't been ale to find detailed instructions on how to get access to behind it.
Post #164119 24th Aug 2012 10:16am
