12v supply behind rear speaker
I have been trying to install a 12v socket in the rear. Following other threads i thought there would be a unused supply behind the offside rear speaker . I opened up the speaker and there are no spare wires there. There is a 6 cable connector there with 5 cables joined through and a white wire with green striped in it that has it 12v going through it.
Any ideas where i am going wrong. Offside (drivers side) 2.2 110 utility.
Thanks2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
18th Aug 2012 9:56am
PaulMc
Re: 12v supply behind rear speaker
Thanks
The connectors that you've pictured are the tail-door harness connection, containing - high level brake light, HRW and RWW circuits.
Looking at the MY12 circuit diagrams and electrical library, the 2-way 6.3mm 'T' connector , with live and earth in it, seems to have been deleted from the build.
The towing pickup connector C0929 has a permanent fused live in it, but this can difficult to connect to, unless you have the towing electrics kit.
.Paul.
