Home > Puma (Tdci) > Puma water pump |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Yep, should fit OK, but you can get the main pump section (LR004799) for £133.65+VAT.
Other options for this part are here, including an OE spec unit. http://www.land-rover-parts-shop.com/en/ui...&stp=s |
18th Aug 2012 5:00pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16901 |
Typical! I ordered one from LR this morning!
Is the pipe connector round the back the same too? Mine seems to be leaking where it bolts to the block, which is odd since I didn't think there was s water passage through the joint face, just oil. |
18th Aug 2012 8:26pm |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 |
Thanks for all of the above,due to time constraints I had to go for the LandRover option.Managed to get my local stealer tolet me have it for trade price.All changed easy job.I have done a post mortem on the leaking unit,all it needs is a new gasket for the impellor section.This does not seem to be available as a part. Its never over in my land rover.
2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
21st Aug 2012 9:31pm |
I changed mine this evening, as you say an easy job taking an hour altogether. Mine was leaking from the drain hole in the bearing housing, which allows the run-off to emerge at the joint face with the block. I guess that the seal by the impellor is leaking.
Will autopsy the old pump later. |
21st Aug 2012 10:26pm |
