![]() | Home > Off Topic > Classic Cars - Ford Capri V8 Perana. |
With Le Mans recently followed by Classic Le Mans we have been loading and offloading some very expensive and fanciable cars of late on the cross-Channel run to Cherbourg and St Malo.
Viewing Ferraris and Porsches and just about every other marque of expensive car became mundane. However early yesterday morning there was a 'growling' from car deck 2 and this came into view. There weren't many made and they were made for the Republic of Africa market and I believe only 200 or so were produced. Having been born in the 60s Ford Capris have and will always endear themselves to me. The one I saw was original and in exactly the same format, colour and decals and it was mint condition and a V8 beast. Details below picture. ![]() Click image to enlarge The basic ingredients of the Perana V8 are quite straightforward: Capri body and 5‑litre Mustang base V8 engine (as used in the Fairlane ) are supplied by Ford South Africa, with some special features to BG specification: 4‑barrel Holley car�burettor with aluminium high riser inlet manifold, 360‑degree dry element air cleaner (all which form part of the Ford Stage 1 "Muscle Power� options), plus Stage 2 cam‑shaft (either hydraulic or Boss solid� lifter) and stronger valve springs. This increases engine range from 4 600 to 5 800 rpm, and output from 156 to 210 kilowatts � almost exactly one‑third more. Gearbox is a four‑speed Mustang close‑ratio unit with floor shift, and rear axle is a Borg‑Warner XB limited‑slip. Imagine a smooth‑handling, quiet-running and low‑slung car that will sprint evenly from 20 km/h (idling speed) to 200 km/h in top gear, that will accelerate with ease from 0‑100 km/h inside 7 seconds, and which has a 50 percent reserve of power at 150 km/h ‑‑ I want it!!!!! ![]() Treat every day as if it is your last....one day you will be right!! |
4 pot Holley & twin 48's phrases from a fab era ( I miss my Mk1 Mexico
Closest I got was a Mk2 1600 M reg Capri with a power bulge bonnet. They like the Puma bonnets were getting knicked at the time for the same reason.
![]() I can fully understand now why Zag gave up his Defender! I would too if the Capri I saw was an affordable option. ![]() Treat every day as if it is your last....one day you will be right!! |
I liked the RS3100 Capri - and like land rovers, they didn't go around corners very well either
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
I like that alot brmm... 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy ![]() |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
i remember watching The Professionals as a kid and thinking their late model " cappa" was the mutts.
Was it a 2.8 (or has that figure come from somewhere else in the old grey matter?) |
3.0S ![]() 1968 1/32 scale Britains 109 Pick up. |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
3.0S ![]() |
The original cars were TR7's supplied by B/L but they kept wanting them back mid way through shoots to give to other companies, so they switched to Ford. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
They (Republic of S.A.) also had a Perana Mk 1 Granada just like the Sweeney one! I looked at one in a showroom in Essex not long ago for �10,000
i was shagging a bird in the back of my mates 2.8 capri when he went through a hedge...............
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
So, he went through a hedge, whilst you were going through a bush?
did bring it all to a head quite quickly as i remember! |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
3.0 GXL was my boyhood dream car in the 70's, the one with the twin headlamps, lovely.....
