Home > Maintenance & Modifications > 3.2TDCI 200BHP into a Defender 90, It can be done! |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
But funnily enough when I run out I fuel I fill it up to Russell
2011MY 110 XS USW Black |
6th Jul 2012 11:13am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
Very nice.
As a side note, I used to drive a shogun 3.2 4cyl diesel SWB (up until last november when it grenaded itself), but that used to give about 24~28mpg driven fairly hard. |
6th Jul 2012 12:36pm |
OK, i've been thinking about this conversion (well... lusting is a better word) and I have some questions please Pete... just generally interested really, most certainly not trying to pick holes in anything
Does this engine use the original chassis mounts? is the 5cyl similar in size and mountings to the puma 4cyl? original radiator? Does much of the wiring loom need to be changed? i figure the original engine loom will be useless as it's only designed for a 4cyl, same with the ECU. does the puma dash wiring need much modification? Will this conversion work with 2.2 and 2.4 original engines? Is the MT85 gearbox the same dimensions as the puma 'box? does the LT230 t/box fit onto the transit main box easily? what autobox fits this engine? Just about to check my lottery numbers for tonight now... I'll be in touch! (if i win..... more than a tenner....) |
6th Jul 2012 10:10pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Hi
Final info a little early to give away as some stuff is not finished. No chassis changes. Neneoverland made engine mounts to lower the engine as their personal choice, original Defender ones do fit but it would possibily need bonnet modification to allow for the bigger bump at the front part of the bonnet due to AC pump and extra cylinder. Egnine is only longer front to back for the extra cylinder the rest is the same. Original radiator and intercooler at this moment in time but will eventually get replaced with larger diamiter intercooler Wiring I cant give more public info just yet on how I have done it. Im swarn to silence lol That said I say have it all patched to the puma dash as it should be so all instruments are as factory temp. rev counter battery light, etc etc The conversion will fit any puma driven chassis with puma mounts, or any defender chassis with new mounts fitted to chassis. Its an Ashcroft puma manual hybrid made for this application, using the transit box with the puma defender back end allowing the LT230 fitment. The standard 2.4 gearbox could possibily be used but it may be weak and would need some slight modifications to mating correctly. Auto is on the cards but not available yet. More will be told in LRO mag soon, with it also available to see on my stand at Billing Landrover Show at the end of the month as long as the owner doesnt want it back first hehe. Pete Last edited by bell-auto-services on 27th Aug 2012 5:41pm. Edited 1 time in total |
6th Jul 2012 10:35pm |
Thanks Pete. It was just for my own (and the forums) interest really.
My hat goes off to you for interogating the electronics and making it all work. just one more... does the super puma anti stall still work? (is this done in the engine ECU? so would it be lost on the transit ECU or can this "program" be transferred over?.... doesn't really matter because when I win the lottery i'll have ARBs or Ashcroft lockers front & back anyway ) |
6th Jul 2012 11:07pm |
ill let you know when i drive it
6th Jul 2012 11:21pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
blimey you mean iv got to cut more off the chassis i think im guna bring my tape measure to billing i dont have air con so hopefully leave the mounts where they are 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
7th Jul 2012 12:10am |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 559 |
I drive a 2010 transit for work with the 2.4 in it and it has anti stall and hill start built in so would presume the 3.2 is the same. |
7th Jul 2012 5:43am |
Anyone for spaghetti ? here is just part of the puma3.2 wiring I have to deal with
Click image to enlarge |
7th Jul 2012 5:07pm |
Good luck mate if anyone is going to be able to do it it's going to be you
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
7th Jul 2012 5:33pm |
32 years as a sparkie on Hercules, Harriers, Tornados and the last 2 on high speed catamarans your picture doesn't frighten me! Try sorting it when it's all been fried and is all charred and blackened due to an engine bleed air leak at 400 degrees....Now we're talking....Bring it on! Good luck! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Jul 2012 5:47pm |
My idea of heaven too, sorting that lot out and looming it all up.
7th Jul 2012 6:58pm |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1376 |
use plenty of scotch locks....and sellotape Putting Dreams on Drives at JLR Solihull..
7th Jul 2012 8:54pm |
LOL! don't bother with scotchlocks, just twist together,
8th Jul 2012 7:04am |
