Home > Puma (Tdci) > Intercooler advice please |
Results were really as expected and certainly no disappointments.....
Finally got round to finishing it all off. Put toolkit in vehicle as a precaution and stayed 'local' in case of any eventualities. Bearing in mind it was 25 degrees yesterday I allowed the vehicle to get hot before heading for the dual carriageway. Even in town traffic engine temperature stayed 5-7 degrees below previous figures under load and when stationary the temperature dropped significantly quicker than previously. Uptake was quicker too where I used to perhaps change down a gear (for example up a prolonged incline) that is no longer necessary. Giving it 'the beans' temperature range remained 5-10 degrees below historical figures and dropped instantaneously when foot backed off the throttle even for a couple of seconds. Figures were monitored on a Scangauge II if anyone is remotely interested. Adding the above figures to the few degrees lost when the cat was removed and the engine running temperature figures are quite impressive. Worth the outlay and compliments the map perfectly in my opinion. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Jul 2013 10:03am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7695 |
good feedback. food for thought.
sorry i missed your De-Cat post, so that brought engine temps down too? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
1st Jul 2013 3:19pm |
Post from two and a half years ago..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Jul 2013 3:59pm |
excellent, thank you Cheers
1st Jul 2013 9:22pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I fitted a Serck intercooler and silicone hoses from Paddocks, good quality and a good price, looks well made, the hoses look good and both seem to do a great job, took about 2/3 hours fitting, just needed a slight mod to the front spars that run at an angle in front of the intercooler, dead easy to fit. Top banana.
1st Jul 2013 11:10pm |
Defmobil Member Since: 27 Jun 2013 Location: Strasbourg Posts: 10 |
Hi,
I read different discuss about intercoolers (and used the search machine), but i still wonder what is the best one (or the best for money if there is not much difference in quality). So, should i buy a Serck, or Allisport, or Alive/Nak/chiptech one ?? Are all modeles welded? or some are simply glued ? and is that a big difference ? Thank you for your advice |
9th Jul 2013 7:47am |
Down to personal choice. I personally decided to veer away from Allisport. Not sure what you are on about 'glued' as they're all welded or so I thought?
I am happy with the choice I made as I am sure is many others. Do you have a remap? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Jul 2013 9:14am |
Thanks for your reply (and excuse me for my poor english; fortunately Googl is my friend.....).
I thought that intercoolers can be fully welded, or sometimes the fins can be simply "glued". I have no remap for the moment, but i plan to take one quickly..... 130 TD4 camper Ex Disco 300TDI |
9th Jul 2013 9:32am |
I personally would go for the remap before a larger intercooler. I think from reports that the difference noticable from just an intercooler without a remap is negligable? Or go for both at the same time if you can afford it!
9th Jul 2013 8:14pm |
Indeed, i'll go for the remap first, and i think buying the intercooler at the same time (if i got time to mount it before going in holidays).
My def is very heavy and think interco will be a great improvement to the remap, also to lower the EGT....but the price can go from one to two and it's very difficult to really compare one to others. I notice your choice, it seems to be great, so maybe ...... 130 TD4 camper Ex Disco 300TDI |
9th Jul 2013 10:13pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
I'm new to landrovers, & Diesels too for that matter, but not intercoolers.
Lots of supercharging done in Aus on all sorts of engines, & of course an intercooler is an integral part of all of this, but to get the full benefit of an "upgraded" one, I would suggest that a remap would be necessary, preferably during, or as soon as possible after, fitting. Cheers, Pickles. |
9th Jul 2013 10:44pm |
Discharge Member Since: 10 Aug 2013 Location: Dubai Posts: 54 |
Is there any consensus on what is the 'best' intercooler? 2011 - 110 - Double-cab pick-up
11th Aug 2013 12:11pm |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
Having had both Serck and Alisport, in my opinion the Alisport fitted better, difficult to say if it performed better as i changed other things at the same time.
11th Aug 2013 12:44pm |
Availability may be the key here perhaps? I personally despite hearing good reviews about Alisport decided to steer clear as I heard unconfirmed rumours that they were struggling to meet demand and that they were in desperate need of recruiting decent aluminium Tig welders. At the same time they pulled their E-Bay advertising. I also did a lot of research and phoning round before committing to buy the one I did!
Do a bit of digging first and see what's about! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Aug 2013 2:02pm |
