Home > Off Topic > show us your coup
Page 2 of 2 <12
Glynparry25
konabikes11 wrote:
Sorry ' Foot * Rolling with laughter And don't you mean RSPCA not RSPB Wink
I had to go check...... and can confirm that the RSPB are still going strong:
http://www.rspb.org.uk/
For a second I thought maybe since I last heard of them they had merged with RSPCA.... I would also have to call the WWF, and Bear Grills!! Rolling with laughter Rolling with laughter
Glyn Dog Sheep
Post #141680 25th Apr 2012 6:29pm
familymad
Yes, was 50m of the stuff and the mains thingy for around £150. Works a treat 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #141882 26th Apr 2012 1:49pm
We have 10 single lines on insulators on 6ft posts 8ft apart. bottom 4 lines 10cm apart and the rest equally spaced apart. Found with the nets that the grass gets into it it bows and shorts ect and also not very high. Foxes can jump. Saying that seen two dead on the road today Big Cry Confused
Post #141900 26th Apr 2012 3:20pm
familymad
I trim the grass around it weekly to make sure but still gives me a bolt even if you can hear it shorting 'clicking' noise. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #148086 1st Jun 2012 11:38am
JWL
A little "trick" we used to use when putting multi strand rabbit fence up was to join every other strand together and connect to the output and join the remaining ones to the Earth return, i.e. strands 1,3,5 etc to Earth and 2,4,6 etc to Live. The idea is that whatever you are trying to keep out is going to hop through the fence, they learn that if they are not in contact with the ground they won't get "zapped". With the alternate power method when they touch 2 wires they get the full brunt! Also if the bottom wire is a return some weed growth won't affect it, but if there is a chance of predators crawling underneath they can miss touching the power wire you just have to assess the situation you have. If it works to electryfy the bottom wire so be it!
Post #148092 1st Jun 2012 11:57am
It's the best solution I have found so far. Trouble is with the chicken wire / netting is they will just go under. No problem if they are shut in at night but they will always strike if ever it's forgotten
Post #148107 1st Jun 2012 1:04pm
familymad
Always shut them in.......agree 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #149824 11th Jun 2012 10:25pm
Page 2 of 2 <12
