Home > Puma (Tdci) > Coolant Hose |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Not heard of that fault before 2.4 90 XS
1st May 2009 3:10pm |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
http://www.aulro.com/afvb/90-110-130-defen...check.html |
2nd May 2009 6:32am |
Forest of Dean 90 Member Since: 29 Apr 2009 Location: Forest of Dean Posts: 68 |
Thanks I'm glad I'm not the only one!!
LR fix was a cable tie around the hose, I wish I knew what a pile of junk these thing are, before parting with money!! |
2nd May 2009 8:32am |
FoD, there not tht bad,you'll enjoy it like the rest of us 2.4 90 XS
2nd May 2009 9:25am |
No offence, but list of faults CD player, Vac pump, Sump pan, the Clutch, water leaks in cab, coolant leak.
Come on this is a new vehicle you dont expect this given the length of time LR has been around, you would think they would know how to put a Vehicle together that didn't require trips back and fourth from the Dealers having faults fixed.(cant be making them any money with all this warranty work) Not get me wrong its a great bit of kit, but I could do without the niggles after all its my works vehicle so it needs to be working when I need it... |
2nd May 2009 1:51pm |
Non taken,the first Puma's do seem troublesome to say the least,hope you get it sorted once and for all. 2.4 90 XS
2nd May 2009 3:07pm |
