Home > Off Topic > Any D3/D4/RRS/FFRR Owners Interested in these ????(NOW SOLD)
noworries4x4
I know, I know they should be in the for sale bit bit they are not for a Defender and not sure about price so using the hated words used on here "gauging Interest"
Set of 4 19" Rims c/w Goodyear MTR "G4" Tyres 3 with 7.5mm left 1 with 9mm left replaced after a blow out on a French Autoroute.
Some light scratches to 1 rim not kerbed just off road marks.
Excellent grip even on wet tarmac, just a bit iffy on side slopes as every one knows.
I am looking for about £650 for the lot c/w rings to fit to P38 or Disco 2 if you want. Full set of tube style wheel nuts and key to operate them.
They cost new £1,400 the lot somewhere in Warwick. I think it was Silverline doing a deal a few years back. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #136097 1st Apr 2012 6:34pm
noworries4x4
If someone was going mad they could even put them on a Defender with a set of those wheel adaptors that were about a couple of years ago, might stick outside the flares abit though. If everything is under control you are not going fast enough.
No Worries 4X4
Post #136099 1st Apr 2012 6:37pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Just advertise them on the disco 3 site they will sell straight away. Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #136126 1st Apr 2012 7:53pm
noworries4x4
Willy if you could chuck a link over it would be much apprieciated many thanks as i am only registered on Defender 2 If everything is under control you are not going fast enough.
No Worries 4X4
Post #136136 1st Apr 2012 8:10pm
willy eckerslike
Will do Original Member Pie n Pea Club.
110 HCPU Tipper
Post #136143 1st Apr 2012 8:29pm
noworries4x4
Many Thanks Willy Ta Bow down If everything is under control you are not going fast enough.
No Worries 4X4
Post #136146 1st Apr 2012 8:33pm
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
they would fit my defender without adaptors Thumbs Up . Unfortunately just bought a set of Bfg mts or would have had these from you Rolling Eyes
Paul
Post #136588 3rd Apr 2012 6:26pm
noworries4x4
Paul
You must have D2 or P38 axles under it then If everything is under control you are not going fast enough.
No Worries 4X4
Post #136611 3rd Apr 2012 7:37pm
marsie
Yep,modded D2 axles Thumbs Up
Paul
Post #136672 3rd Apr 2012 9:53pm
noworries4x4
19" wheels would fill those arches better Laughing Laughing
I know Wildcats use the D2 axles the front casting and ball joints are even stronger than 7 bolt 110 swivel housings but dont see the advantage of converting them under a Defender. The hub bearing assys are a pain. If everything is under control you are not going fast enough.
No Worries 4X4
Post #136673 3rd Apr 2012 10:10pm
marsie
We run them on our challenge cars as well. like you say-massively strong and 4" wider than stock 90/110 axles(my axles are now exactly the same width as before but without wheel spacers) but other than that no real benefit on a road car. Doing car as a rolling advert so will have plenty of mods.Also have a mate in the dealers that changes D2 bearings when they get a ABS faults but mine hasnt got ABS so have a ready supply of suitable hubs/bearings Thumbs Up
Paul
Post #136678 3rd Apr 2012 10:18pm
noworries4x4
Just changed all the corners on the P38 above they had all gone noisy at 130Thou, i went down the cheats route, dealer hubs at £350 a corner i don't think so, smashing the hubs to pieces in a press where the bearings are glued in did not fancy that either so got mine from a low mileage smashed up one, just praying it was not kerbed heavily in the accident but they are silent at the moment. If everything is under control you are not going fast enough.
No Worries 4X4
Post #136681 3rd Apr 2012 10:30pm
noworries4x4
I have not had any interest on here so now listed on ebay for 7days from Sat 7th for 7 days but if anyone wants them for more than £650 i will remove them ok If everything is under control you are not going fast enough.
No Worries 4X4
Post #137692 7th Apr 2012 7:30pm
noworries4x4
http://www.ebay.co.uk/itm/130677627101?ssP...1555.l2649
This is the link if anybody wants them If everything is under control you are not going fast enough.
No Worries 4X4
Post #137762 8th Apr 2012 9:21am
noworries4x4
Well the ebay colour has just gone green someone has met the reserve @ £600 with 6 days to go. If everything is under control you are not going fast enough.
No Worries 4X4
Post #137892 8th Apr 2012 6:58pm
