Home > Puma (Tdci) > Rough at startup and smoke |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Mines the same when it's cold.
Monday was the worst as I'd not used it all weekend and was covered in snow and ice. Gave it a couple of glow plug cycles but it fired up after three or four turns of the engine, sounded like a bag of spanners and chucked out a lot of smoke, but after 10 seconds or so it had settled down. When it's warm or during the summer it's fine. I'd be tempted to say its normal (mines recently been serviced too), but don't hold me to it. |
9th Feb 2012 10:52pm |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 |
Mine did that when my egr was making loads of noise, got the egr taken off and greased up, all is well now 90 Puma HT
9th Feb 2012 11:02pm |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 |
Mine was bad last week. Healthy battery, just turning over but wouldn't fire. Smokes a lot on start up and runs rough. Soon clears though.
10th Feb 2012 8:33am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Have the EGR checked, mine did the same a few years ago.
Glyn |
10th Feb 2012 2:08pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
I have noticed that mine has been doing this too on the recent cold mornings, a few seconds of dense whitish smoke whcih clears in a few seconds, and even more rattly than normal.
As far as I can tell, the EGR is still working properly (at least it still makes the ugga-ugga-ugga on switch off). |
10th Feb 2012 3:35pm |
d92qyh Member Since: 08 Apr 2011 Location: UK Posts: 6 |
Thanks for all the replies. Still having the same issue (seems to be blueish smoke) on first startup with rough running but really no problems at all after 5 seconds.
Never seem to have any problems after the initial first start of the day as recently left it for 8/9 hours in the day after driving to work and no issues when starting in the evening. Due for a service soon so will get it looked over. |
12th Feb 2012 3:15pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2598 |
chuck in some 2SO and see if it makes a difference? It may just clean up some carboned-up components. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Feb 2012 9:13am |
StuLandy Member Since: 28 Jul 2012 Location: Here, there and Everywhere!! Posts: 43 |
Hi all, great site..some really usefull stuff on here...My Landy has just started to do this after filling up with Tesco's fuel. Back on the Asda stuff now but seems to be getting progressively worse..may not be fuel related but some pointers/ideas would be helpfull..
cheers |
28th Jul 2012 11:23pm |
Captain Speaking Member Since: 23 Jan 2012 Location: Oxfordshire Posts: 159 |
Sounds like the EGR...my D3 was just the same, and it was indeed the EGR.
Re Tesco fuel - don't do it!! I use Ultimate etc and it really does make a Difference. |
29th Jul 2012 11:58pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
I use Tesco Diesel + 2so and have done since new - No Problems , 2010 90 XS and now has 25,000m + on the clock. Only time I don't use Tesco is when I'm travelling when I use whatever is available. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
30th Jul 2012 6:57pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Sounds like my TD5.
Only started after the EGR was blanked. After initial start everything is fine. Changed the MAF, no oil in the harness, no apparent oil loss, no water problems My Puma blows a bit of blue smoke in the winter on first start but that is just a little unburnt fuel. TD5 is back in next week and the workshop are going to have a look to see if they can find the cause. In my case it may be down to something gummed up due to very little use, I am sure all will be revealed soon Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
30th Jul 2012 7:17pm |
It sure does. I have been using cheaper French supermarket diesel for years, and the engine hammered away rather distinctly, and on turn off, the EGR cleaning "chuka chuka" was quite loud.... About 4 months ago I switched to using BP Ultimate, and immediately noticed a change in engine sound level, much smoother, less hammering. And the "chuka chuka" has become a nice quiet discreet cleaning cycle. I have no idea about any change in fuel economy with BP Ultimate, but one thing is for sure, everything works like a dream now. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
30th Jul 2012 7:44pm |
Cheers for the replys lads, got back onto the Asda fuel, threw about 300ml of 2so in on a full tank and all is well, less smoke on start up and not lumpy. Seems a little quieter and the egr valve cleaning cycle is less prominent sound.
Would you always put 2SO in every fuel up or every other. Would you use 2so with bp ultimate (only when i'm flushed with funds will she get BP). |
4th Aug 2012 10:51pm |
I'm using BP Ultimate without anything else... Smooth as can be now. You never actually own a Defender. You merely look after it for the next generation.
5th Aug 2012 4:52am |
