Home > Maintenance & Modifications > fitting some puma seats in the rear of the td5 90 |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 610 |
Been busy then!!
You beat me to it too, I just posted my pictures of the ebay advert doing this very modification! |
22nd Jan 2012 6:14pm |
you don't mess about Boy!
good idea that, makes the retro fitting of seats APOP! |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
yer dnorrishill just saw it lol and t1g up its just gotta be done mate roll on next weekend i say ill order the soundproofing tonight from fleabay then carpet from land rover in the week thats if its in stock
22nd Jan 2012 6:16pm |
Stupid question, but I assume you have the seats, belts, etc. - were they expensive?
22nd Jan 2012 6:18pm |
lucky enough for me mate dad is removing his ones out of his new puma as he said they take up alot of space for what he uses his one for so happy days they cost me £0.00 but they are on ebay for around £500 its just waiting and finding the best deal ill keep an eye out for ya
22nd Jan 2012 6:20pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Lovely job
Can't begin to tell you the problems you'd have doing such things in Germany - seriously cramps my creativity Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Jan 2012 7:27pm |
yer it is really unlucky for ya mate i dont think they would accept this over there either you watch soon our laws will change that my excuse for doing everything now
22nd Jan 2012 7:35pm |
we're going to need more pictures killer90 !
where did you get the wheel arch fabrications from ? are they reinforced ? |
22nd Jan 2012 7:37pm |
more pics to come very soon they are very well fabricated got them off of a guy who unfortunately no longer makes them due to alot of time wasters i was lucky as it was his last pair, they are double skinned so reinforced reasonably well were needed, all we had to do was cut the original arch as the pic shows and rivet the new pieces over the top i gotta seal them all off properly and paint and waxoil the underneath once thats all done it should look original
22nd Jan 2012 7:44pm |
Nice work Killer, surprised that you didn't 'wet assemble' the inserts whilst riveting them in, would have made a better seal!
Lucky with the seats too! Wanna pick six numbers for next weeks lottery for me? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Jan 2012 8:20pm |
k9f cheers i have sprayed all around were we cut then tiger sealed and bonded along the arch and also the fabricated piece pushed it down and it oozed out so got me hand under the arch from outside and smeared it all around the seems then gunna rivet it then after silicone all the seems again and also the welds just to be sure then spray the underneath black then a few coats or waxoil out of the spray gun that should keep the water out me thinks more pics tom come soon
22nd Jan 2012 8:49pm |
Goldstar Member Since: 24 Oct 2011 Location: Yorkshire Peaks Posts: 10 |
Hi K90. Looks like a very neat job. I'm probably teaching you to suck eggs but the Puma has a tiebar or tube that connects between the rear crossmember and the underside of the wheelarch. Its held in place by a square plate with 4 bolts welded on it, a torx bolt and the lower seat belt anchor bolt i.e. 6 fixings. 2 torx bolts through the crossmember complete the fixing. Landrover say this is essential for the safety of the rear seat and belt installation. If you need further info I have pics from the job I did installing Puma seats into the load area of a 5 seat Puma.
22nd Jan 2012 8:51pm |
cheers matey yer already know about the bar but thanks anyways the td5 has a similar bar which again is in place for the seat belts and also there is a bar inside of the td5 which the lap belts attach too i am either going to stick a couple of lap belts in save all the faffing about or fit the genuine belts as i do have access to these just not the interior trim
22nd Jan 2012 9:02pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Killer, your 90 looks amazing
22nd Jan 2012 10:39pm |
