Home > Wheels & Tyres > tyre sizes for Boost alloys |
285s
just sold a set! |
15th Jan 2012 5:04pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Any tyre taller than 235's will effect gearing but depends on the size. Boosts are 7 inch wide and this will restrict the tyre size.
This link will give you a guid. (click the veiw spec link on the right bottom) http://www.bfgoodrichtires.com/tire-select...spec_table I too have 285's running on 8.5 inch rims, if anything else it makes the speedo run true |
15th Jan 2012 5:26pm |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
i have 265s.
Went on my standard 90 without any rubbing or modification Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
15th Jan 2012 5:31pm |
The common sizes are either 235/85, which is how they come from the factory, and 265/75. The latter are, as near as makes no difference, the same diameter as the former so they're interchangeable. Darren
15th Jan 2012 6:22pm |
Reiver Member Since: 04 Dec 2011 Location: Cumbria Posts: 48 |
Only other thing I would add Alan is the question of whether your turning circle would be compromised with wider track tyres? It'd 'ollocks at the best of times
I'm sure the others here would know, but I've just fitted 30mm spacers to get something appearing sensible. This is border country and the Romans built a wall for a reason! |
15th Jan 2012 6:29pm |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 |
thanks guys..... just find the whole tyre thing sooooo confusing. Dont want monsters, just something slightly wider, and will put spacers on if needed. Life is not a rehearsal!
Def 90td5 CSW xs 2006 |
15th Jan 2012 8:32pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2259 |
Actually boost wheels are 7.5" Puma 110" SW
15th Jan 2012 11:55pm |
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 |
This old chestnut. I have run 285/75 on boosts no probs although it will affect the gearing and it doesn't catch the arches, although they can catch the radius arms on full lock.
Depends on what you are trying to achieve really. |
16th Jan 2012 12:05am |
ngarigo Member Since: 25 Nov 2011 Location: Alice Springs N.T. Posts: 81 |
265 cooper s/t maxx's on standard.... sweet...!
27 by Defender 90, on Flickr Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... 'Wow...! What a ride! MY11 90 |
16th Jan 2012 4:35am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7683 |
so width wise you can run a 285 on a boost alloy ok? just looking for some 33" ish tyres for the 90 puma i just picked up, the 235.85s are just too small looking with the 30mm lift it has. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
3rd Dec 2015 9:28pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
Tyres are not sized solely by width, you need to consider the height (percentage of width) as well.
This way, 235/85R16 tyres are the same overall height as 265/75R16. The overall height which is what you should aim to keep the same or very similar 1988 90 Td5 NAS soft top 2015 D90 XS SW |
3rd Dec 2015 9:38pm |
Hi Martin, thank you for reply, yep well aware, i am trying to acheive a 33" ish height, the brand and tread i want only do that in a 285, just wondering if that will fit the boost rim, 7.5J is it? Cheers
3rd Dec 2015 9:42pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
255 85 16 any good for.ypu james? 2004 TD5 Defender 90 xs station wagon
3rd Dec 2015 10:50pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Since when? |
4th Dec 2015 12:16am |
