![]() | Home > Puma (Tdci) > For our friends in the nordic countries and russia |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Puma Engine Breather Pipe Freezing
Models: Defender (LD) 2.4 Diesel Puma Only VIN-range: 7A732615 Onwards Markets: Russia and Scandinavian Markets Only Section: 303-00 Summary: Engine oil leaks. Cause: Driving the vehicle at temperatures on or below Zero deg C, freezing of the engine crankcase breather hoses resulting in engine oil leaks. Suggested Customer Concern Code - D50. Action: Should a customer express concern, install a new heated breather kit. Follow the Service Instruction outlined below. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
Thanks |
Glyn,I would contact your dealer tell them of this issue making them aware you travel abroad alot in similar temperatures. 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
I want to know what the heated breather looks like Mike
Hi there
There is some pictures in the report. When I had a little bit more time I will put the entire bulletin in the net. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
