Home > Puma (Tdci) > PAS - not the pump!
alantd
PAS - not the pump!
Just as I left the driveway yesterday my steering started making a horrible noise and getting very heavy. A quick look underneath and there's fluid dripping all over the drive. Inside the bonnet and there's fluid sprayed everywhere.
Ah ha! I thought. I know what this is - clearly the PAS pump seal has gone (knowledge courtesy of Defender2.net).
Land Rover Assist were here within the hour. The guy had a quick look and revealed that actually the hose connecting the pump to the steering had come loose. The fluid had sprayed out and onto the PAS pump belt at the front and then been catapulted round the engine bay.
1 x 16mm spanner later and we were back in business.
He had no explanation as to why the hose had come loose and had never seen it before. I recall now that spudfan had a similar issue although his wasn't ever tight from assembly. Mine has done 9000 miles so I've no idea why it has come undone now.
LR assist's advice - monitor it regularly to make sure it doesn't come loose again and carry a 16mm spanner Neutral One that started out as a 2.4 TDCi 110 XS
Post #8343 12th Mar 2009 12:18pm
110SEB
Re: PAS - not the pump!
alantd wrote:
He had no explanation as to why the hose had come loose and had never seen it before. Neutral
I do. Our cars are put together by a bunch of Brummies (I am one so can be rude) in a British Leyland factory with a British Leyland attitude that runs from supplier of the front windscreen washer sprayer (see thread this week) right through to the dealers - permeating everything in between.
If ever there was a case of "compu'er says no" Land Rover is it.
Never-the-less I still LOVE our 110 and Defenders of ALL kinds. Heart over head? You bet!
Thumbs Up
Post #8346 12th Mar 2009 12:30pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I knew there was a use for a 16mm spanner!
Actually I've seen a reference to it either here or on another forum from another of the Australian Puma owners. I remember at the time checking mine and finding it to be tight. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #8347 12th Mar 2009 12:32pm
alantd
The LR assist guy didn't have a 16mm spanner with him!
He was digging around for ages and then asked if I had one.
"Never use a 16mm" he said.
"Never worked on a Defender" I thought. I seem to have every combination of metric and imperial on mine. One that started out as a 2.4 TDCi 110 XS
Post #8357 12th Mar 2009 6:52pm
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
My hose came lose after 10000 km whilst off road. Had a pretty good upper body work out on my way to the dealership. Land Rover's don't leak oil, they simply mark their territory!
Post #8371 12th Mar 2009 8:16pm
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Both mine and I think TimmyNZ's suffered from this. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #8377 12th Mar 2009 9:47pm
alantd
Not so rare then.
Interesting. I guess it's another to add to the list. One that started out as a 2.4 TDCi 110 XS
Post #8379 13th Mar 2009 12:23am
Eduardo
Other thing to be check.
At least is not a big one
Maybe in some days we will see a bulletin with that.
Cheers! Eduardo
Post #8391 13th Mar 2009 11:59am
