Home > Technical > Swapping rear panels. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5408 |
Wow. Looks like I will be the first to do this then.
23rd Oct 2018 6:14pm |
It can be done by unbolting the roof from the sides and then easing the roof up enough to swap the panels over. Prop the roof with some timber - it only needs to be lifted a couple of inches. You'll have to take out enough of the roof to give access to the bolts, which will be at least the rear and centre sections. Darren
23rd Oct 2018 6:36pm |
Thank you. Fixings for ceiling are reusable or should I buy new for refitment.
Andy. |
23rd Oct 2018 6:39pm |
You should be able to reuse them if you take them out carefully. I've had the lining out of mine twice and reused the fixings without issue. Darren
23rd Oct 2018 6:41pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1829 |
Fixings are reusable - just nuts and bolts.
I did almost the same thing last week (some pics on my 'tinkering' thread - in my sig below). I wasn't replacing roof panels though, just adjusting them, but it's effectively the same thing. You might need to get your roof a little higher to be able to clear the corner fixings in the tub. Good luck! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
23rd Oct 2018 6:46pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
This is a pdf that was sent to me from Bearmach. It is for a 110. Sit down when you get to the prices!
https://www.defender2.net/gallery/albums/u...armach.pdf Peter |
23rd Oct 2018 7:01pm |
Thanks. I’ve got the panels, and had them sprayed for me.
Click image to enlarge |
23rd Oct 2018 8:12pm |
Here we go then.
Click image to enlarge Should have bought new fir fixings for ceiling lining though. Everyone apart from two snapped. I’m sure I would have had more success if it was above 3degrees C today Andy. |
27th Oct 2018 11:15am |
That’s better
27th Oct 2018 12:34pm |
All done and I’m much happier with it.
27th Oct 2018 3:26pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 657 |
Looking great
27th Oct 2018 3:29pm |
Looks very smart Darren
27th Oct 2018 7:08pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3000 |
Very nice work.
27th Oct 2018 7:23pm |
Thanks I’m very pleased with how it looks.
Got to clean the CSW rear panels up, and get them listed for sales to get some of the outlay back now. Andy |
28th Oct 2018 8:53am |
