Home > Tdi > Prop shaft
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Prop shaft
Anyone tell me the length of the rear prop shaft on a 90 300tdi .
Post #734196 11th Oct 2018 12:13pm
Martin
Site Admin
http://www.ep90.com/propshafts-ujs.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #734198 11th Oct 2018 12:37pm
tolley
Many thanks, mines 700mm and it's seems tight and rubber sleeve as spilt.
Post #734201 11th Oct 2018 12:43pm
tolley
how much travel should it have on the shaft .
Post #734262 11th Oct 2018 6:55pm
jst
It only needs 20mm travel or Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #734279 11th Oct 2018 7:55pm
tolley
Just concerned about the rubber sleeve being spilt and looks like it been squashed.
Post #734287 11th Oct 2018 8:40pm
jst
pull the sleeve off the wider part and check condition of the splines - are they corroded? i have not checked how long yours should be but if it fits and can be removed with the vehicle on level ground, not jacked and there is still 15mm or so further compression from the amount you need to compress it to remove it i would suggest its ok. Has the vehicle been lowered? Cheers
James
110 XS Utility
90 Puma Hardtop
Post #734323 12th Oct 2018 7:37am
tolley
Thanks James the prop is nearly new, not lowered all standard.
The old was even tighter to get off .
Can the transfer box be different length. Just thinking maybe someone fitted a none standard one.
Post #734343 12th Oct 2018 10:23am
jst
How many miles has it done since fitting? Do you have 10mm or so compression as described above? Cheers
James
110 XS Utility
90 Puma Hardtop
Post #734352 12th Oct 2018 12:09pm
