Home > Puma (Tdci) > Puma 2.4 fuel economy got worse
Page 2 of 2 <12
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
I am quite sceptic about putting Censored into my engine too. I went to buy a fuse in a moto-shop and then had this impuls to get a bottle of Ceratec and give it a try.
I was surprised by the effect in a big way. I was not expecting to see any significant improvement and then I looked at the fuel level and trip distance. So, I put fuel to make counts. That was the first fuelling when I got 9.2l/100 km. After I made almost 400 km on a highway and I put fuel again to see those 10l/100km (a bit more than 10, because I put the tank really full).
I have been having, as you can read in my first post of this thread, bad fuel economy for 2 years and now this surprise. I am still not sure what to think about it... Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #734212 11th Oct 2018 2:42pm
Porny
Site Sponsor
I'd replace the injector seals and redo the pilot injection learn.
Also - have you still got the EGR valve in place? IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #735276 17th Oct 2018 12:54pm
Bergos
So, new update on my fuel economy.
The car had been parked for 2.5 months with full tank.
After driving on mixed roads for around 900 km I put the tank full again and the fuel consumption went up again to 11.65l/100km (8.58km/l, 24.24 iMpG).
I am confused and don't know what to think about the situation. Was the Ceratec just a coincidence or it had an effect indeed but short lasting...
Or maybe the diesel in my fuel tank is not so good after 2 months...
After I did 400+ km on a highway and didn't fill up but I am sure that the results would be even worse.
So, what can cause the fuel economy to go up and down from 9 to 13 l/100 km?
Any hints? Bergos
Post #750035 8th Jan 2019 7:28pm
Bergos
Hi.
Years are passing and the fuel efficiency of my car is not improving. I would say - it's gradually getting worse...
The car is serviced regularly. ECU does not record any errors...
EGR has been removed. I rarely use the A/C.
Do I have unrealistic expectations? Sometimes the car goes below 10 liters but it's exceptional and there is no clear pattern here...
And this is correlated with the unresolved engine temperature issue described here: https://www.defender2.net/forum/topic56815.html Bergos
Post #921020 11th Sep 2021 1:09pm
Bergos
Well, well, seems that I have killed two birds with one shot - changing the radiator solved the overheating problem (see: https://www.defender2.net/forum/topic56815.html) AND the fuel economy problem!
So, if your radiator is more than 10 yo and you have any of these problems or both, do not hesitate. Start with the radiator! Bergos
Post #932429 4th Dec 2021 6:08pm
Mago
Germany
Very interesting, thanks for that.
My radiator is about 12 yeras old, since about 1.5 years I noticed a higher fuel consumption.
Checked all the usual parts, everything ok. Could you please explain which defect is affecting the radiator exactly?
Greetings
Very Happy Defender 110 TD5
Post #932608 6th Dec 2021 1:11pm
Bergos
I guess it is the internal corrosion. Something you don't see and is very difficult to notice and diagnose.
I knew about the overheating problem because I have a digital gauge showing me the real-time temperatures (water and oil). Without it you wouldn't notice anything until 115C when the ECU cuts the fuel.
I was not believing that the radiator is causing the problem, but seems that it really was. The OEM replacement is quite affordable and definitely worth it!
Seems that they last +/- 8 years and need to be replaced. Probably depends on a few variables - coolant quality, frequency of use etc. My car rests for months and is used only during holidays which can make the corrosion worse. Bergos
Post #932972 9th Dec 2021 2:41pm
Mago
Germany
Thank you.
Maybe I´ll do a testdrive without the radiator and see if there is any difference.
Greetings
Post #933282 12th Dec 2021 2:45pm
Bergos
You want to do WHAT??? Bergos
Post #933843 16th Dec 2021 2:32pm
Mago
Germany
Oh lala, there is an essential part of information missing. Shocked - Thanks Bergos!
I have a new radiator in my garage, the idea is to replace the old visco-radiator for testing.
Sorry for the missunderstanding .
Greetings
Post #934124 18th Dec 2021 5:23pm
Bergos
Just to make sure we are talking about the same things...
This is a radiator:
 Bergos
Post #934174 18th Dec 2021 11:58pm
Ecco
Malaysia 2014 Defender 110 Puma 2.2 DCPU Galway Green
..i did noticed slight difference in fuel consumption, between Petronas and Shell fuel..truck was used on same way(city drive), so i guess, fuel seems to contribute for some reason..
Post #934183 19th Dec 2021 4:44am
Mago
Germany
Yes, the large radiator next to the intercooler. Not the large Fan Whistle
Of course I do not make any testdriving without the radiator.
Greetings,
Post #934243 19th Dec 2021 3:16pm
spudfan
Ireland
Maybe a simple flush out of the radiator and coolant system would help things. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #934611 21st Dec 2021 11:46pm
The OAT coolant is supposed to have a life of approx 5 years if I remember rightly.
Draining and re bleeding isn’t as complicated a job as it first seems, the more difficult part is having to go out of your way to dispose of it correctly.
And that being made more of a pain in the backside than it should be.
Is there much work involved with the rad replacement? Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~
I got’ love for Britain, I got’ British pride’. 🇬🇧
Post #934740 22nd Dec 2021 9:27pm
Page 2 of 2 <12
