Home > Tdi > Prop shaft |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
Anyone tell me the length of the rear prop shaft on a 90 300tdi .
11th Oct 2018 12:13pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6463 |
http://www.ep90.com/propshafts-ujs.html 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Oct 2018 12:37pm |
Many thanks, mines 700mm and it's seems tight and rubber sleeve as spilt.
11th Oct 2018 12:43pm |
how much travel should it have on the shaft .
11th Oct 2018 6:55pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
It only needs 20mm travel or Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Oct 2018 7:55pm |
Just concerned about the rubber sleeve being spilt and looks like it been squashed.
11th Oct 2018 8:40pm |
Thanks James the prop is nearly new, not lowered all standard.
The old was even tighter to get off . Can the transfer box be different length. Just thinking maybe someone fitted a none standard one. |
12th Oct 2018 10:23am |
How many miles has it done since fitting? Do you have 10mm or so compression as described above? Cheers
12th Oct 2018 12:09pm |
