Home > Technical > Utility parts. |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
I use this site:
https://www.landroverworkshop.com/ Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
9th Oct 2018 5:56am |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1185 |
All you need is a set of hard top side off an 88" Series. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
9th Oct 2018 7:24pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5416 |
I’ve bought the utility panels, and now need to get them sprayed. But it’s the fitting parts that I require.
Sides to roof seal Sides to tub seal Anything else? Andy. |
9th Oct 2018 8:34pm |
I reused my seals as they were in good nick. But then again it's a 300Tdi so back when things were reasonably well built
Only addition I did was run a bead of rtv around the tub to sides for extra waterproofness. Was able to do it without taking off the roof. Unbolted everything and with a sledge hammer between the wheel box and back door top was able to prop the roof up high enough to install them. I had to split one of the nuts in the rear corner and the thread was knackered so I turned down what remained on the lathe and drilled a threaded bar to slot over the top and welded it in place (more because I could and didn't have time to wait for new parts to arrive). Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
9th Oct 2018 8:39pm |
One addition that has worked well for me is I also tinted the rear window quite dark (from Halfords). Now means I can have guns and stuff in the boot without being too obvious. The L322 seats block off all visibility from the front as well. Ed
9th Oct 2018 8:40pm |
I will be getting the two rear passenger doors, and back door window tinted limo black. I will also pu seal between new utility panels, and side cappings.
Want to keep it as secure as possible as it’s my work van, and also to keep it cool, as it’s also a kennel. Andy |
10th Oct 2018 8:19am |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Bushpig
Thanks for a great link. This is going to be very useful |
19th Oct 2018 7:30pm |
