Home > Technical > td5 rev counter |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Well done Chip butty and Stefan
Just a shame that CAI didn't include that vital info on their installation sheet, would have saved everyone a lot of bother |
28th Aug 2018 5:51pm |
chip butty Member Since: 12 Mar 2018 Location: manchester Posts: 8 |
Hi Gerard Td5
My 90 does not have ABS. there was no wire on pin 19. Hope this helps. |
28th Aug 2018 9:15pm |
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 |
I hope that all rev counters now function. It is suddenly no longer a topic. There were more rev counters that did not work, I am only curious about the experience of the others.
Gerard90Td5 |
7th Oct 2018 1:32pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I've still not bought one because I was waiting for more people to say they sorted it before coughing up 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
7th Oct 2018 4:13pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 860 |
Mine works now too with the new wiring configuration which included the use of the internal pull up resistor on my non abs td5
7th Oct 2018 6:21pm |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 103 |
Hi all, sorry to drag up this old post.
Has anyone fitted one recently made by smith gauges from rimmer bro’s?? I’ve got it wired up correctly as in the previous page, Red/blue-----------------------pulse from pin 19 red-----------------------------ign. live 12v green--------------------------ign. live 12v black---------------------------earth red/white----------------------gauge illumination 12v from other gauge or side lights No white/black cable in this plug. however, The rev counter doesn’t move at all, main problem one. Have run the wire direct from the ecu (even though I’ve got the cable fitted up to the dash loom from factory!) Second problem, the illumination of the gauge works without the ignition on, when ignition is switched on, the illumination of the gauge turns off. All wiring has been check over numerous times, and tested with a multimeter. |
22nd Feb 2022 6:34pm |
Gauge is on its way back to rimmer bros. Who will return it to Smiths/ Caerbont who make them. Must be a faulty unit..
23rd Feb 2022 5:44pm |
BullzeyeTD5 Member Since: 11 Jan 2024 Location: Staffordshire Posts: 1 |
Hey buddy, just wondering what your final fix was and is everything still okay? Hopefully you will still reply |
11th Jan 2024 10:55pm |
Register Member Since: 11 Jun 2023 Location: London Posts: 82 |
Everything you need to know is on here.
&t=438s At least I hope so as I've just spent a whole £17.68 on this quality item. https://www.ebay.co.uk/itm/314487483380 Pete Everything's a hammer. |
16th Jan 2024 6:30pm |
